10-06-2006, 08:20 PM | #1 |
March Serpentine and power steering help?
I've got a March Equipment Serpentine kit that came with it's own PS pump...
I need to add a remote reservoir (Which I have), and then need to plumb into the steering gear... The PS pump has the return line pressed into it, and it actually turns underneath, and toward the oil pan.... Anybody have any pointers or resources?
Avatar is a pic of "Before"... Just wait.. ---------------- 1969 Fleetside: Shortened frame for SWB, ECE 4-6 drop. ECE SS tank. All new ECE suspension. Rebuilt 12 bolt 3:73 with Eaton Posi. Front and rear disc brakes. Ramjet 350 and 700r-4 trans. 20" Centerline wheels with Kumho 295/45/20 tires (I hope they fit). Progress pics: http://s44.photobucket.com/albums/f2...uck/?start=all ---------------- Seriously... It's nothing a large dose of cash can't fix... Right? After all, I can't take it with me when I go... Just gotta have enough to get there!!! |
10-06-2006, 10:44 PM | #2 |
"See the U.S.A....."
Re: March Serpentine and power steering help?
Can you just heat it then bend it?
1970 short bed fleetside 1949 all origional chevy 3600 1974 camaro Richmond , Texas(just S.W.of Houston) |
10-07-2006, 04:53 AM | #3 |
No, the fitting is pressed into the pump... I might be able to pull it out, rotate it, and then press it back in, but I was hoping someone else has been here and had a better solution... It'd save me a ton of heartache...
10-07-2006, 08:56 AM | #4 |
For the price of that, wouldn't it be better to ask March. JMHO. That is one nice piece of equip. I've dreamt of that, someday maybe I'll be rich
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
10-07-2006, 06:12 PM | #5 | |
08-20-2007, 03:33 AM | #6 |
FYI:
I was able to "finesse" the fitting... I got a medium-large crescent wrench, and "muscled" the fitting... it did turn, and all is well.. Truck runs, PS works! I hope it helps someone out there who was scratching their head wondering what do do in a similar situation..
08-20-2007, 07:32 PM | #7 |
That's right, it's Copper!!
I have the same system. The truck is not finished yet and had not noticed this. Thanks for the heads-up!!
08-30-2007, 02:45 AM | #8 | |
This board has helped me SO many times!!! I'm glad I could contribute. By the way, wasn't Harvick from Bakersfield?!
08-30-2007, 04:08 PM | #9 |
Yep!!
I used to work with his Dad. |
