Old 10-07-2006, 12:13 AM   #1
byrd
Union Electrician
byrd's Avatar
pinion angle
I have my rolling chassis set up for a 5" rear drop(3" springs and 2" blocks)and a 3.5" in the front will this amount of drop cause any issues with the pinion angle? If it will how much drop can you have without affecting it.
TIA ..Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 10-07-2006, 04:38 PM   #2
powell72
powell72's Avatar
Re: pinion angle
I've had an airbagged truck and the one I have now is dropped 6'' in the back and I have never had an issue with the pinion angle. No problems at all with a 5'' rear drop.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 10-07-2006, 04:56 PM   #3
larry may
Re: pinion angle
Hmmm! Intresting to me .Randy I laid a triangle with degrees wheel that indicates degrees. I set it on top of the tranie where the drive shaft slips in .noted the degrees then set it on the drive shaft noted that degree . Then I checked the angle in degree for the differential. The diff is 3 degree lower. It does just fine , Did not know exactly what I was doing anyway . and works just fine. My old drag race car is 7 degree below level. works good. 12 years still all good.my .02%
Found an older thread that may help you out here. Lots of wizzadrs have left their information here. Is this site not the best..........Larry
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 10-07-2006, 11:09 PM   #4
larry may
Re: pinion angle
Date 1 01 2006 page 16 in suspension . this thread may help. Larry
Old 10-08-2006, 05:30 AM   #5
SlammedDime
SlammedDime's Avatar
Re: pinion angle
Here's something I wrote up on u-joints and driveshaft angles... it may help you a bit in taking measurements to be sure everything is in order.
http://www.airridetalk.com/articles/...-joint-enigma/
Matt
Admin @ AirRideTalk.com
Win FREE Viair compressors!
SlammedDime is offline   Reply With Quote
Old 10-08-2006, 08:15 AM   #6
byrd
Union Electrician
byrd's Avatar
Re: pinion angle
THanks to all for your replies. I Like powell72 responce the best, no worries!! It looks as the rear is kick up a bit since I lowered it, but I don't have the tranny or driveshaft in yet either. I will check it all out in about a month when the tranny gets here. Thanks again guys!!!
Zip:40272
