I poop on Ford!
Anyone with a Blazer have a belt system that includes more than a lap belt? It doesn't appear that there is anyway to rig a 3-point system. I was wondering if any of you have done a racing style harness in yours.
I drive mine daily and occassionally I have my young son with me. When the top is off I really get concerned. I guess I could get a low profile headache bar installed behind the seats and have a mounting point welded to it on either side. This would solve two problems. Any ideas? Pictures? ------------------ 1972 Chevy Blazer 2WD - 400 SBC, bored, ported/polished heads, 9.5:1 dished pistons, Lunati 480/292 cam, electronic ignition, Edlebrock Performer intake, tricked out Rochester 850CFM Quadrajet, long tube headers, Flowmaster 40's, TH350-C with lock-up switch, 2800 rpm stall, shift kit, custom driveshaft, stock GM 12- bolt rear with Auburn Pro Series limited slip 3.73's, 2" drop spindles, 2" drop rear coils, track bar kit, front/rear stabilizers. 1999 30th Anniversary Trans-Am Coupe #1494 - M6, Flow-tech cut-out, Flowmaster, free mods. One of 292 coupes with M6 and in-dash CD.
1972 Chevy Cheyenne - LWB, factory 402BB 2005 Chevy Suburban LT 2006 Chrysler 300C - SRT8 |
Member since 2000
theres a companys called "CROW" that make full harness 4-point belts, there a good company check them out.
------------------ Mechanic @ California Concept Britney: 1970 2wd K/5 Blazer (Frame up) Jessica: 1967 2wd SWB (pops daily driver) Helga: 1972 4x4 3/4ton LWB (my daily driver) AIM:Alexmart1 Mountain View, Cali |
its all about the +6 inches
The thing to remember, anything not installed (or available) orii=ginally, is not leagal for street use. Most cops don't care, but some do. Inspection stations do care.
------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
aka Crusher, Crushergmc
Good point longhornmail. Just leave the old ones in no matter what else you do.
[This message has been edited by 70 Jimmy (edited April 22, 2002).]
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" |
SKINNY TIRES RULE!
Most people attach them to the roll bar. Someday, when and if I get around to it, that's the way I'm going to do it. If you don't have a roll bar, I would suggest installing one. The fiberglass tops don't provide a lot of protection in a roll over and if your running topless... well, you get the idea.
------------------ '69 K-5 Blazer - 350/TH350, 6" lift, 35" tires Bothell, WA
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
I poop on Ford!
alexmart1:
Do you have a link to a website? ------------------ 1972 Chevy Blazer 2WD - 400 SBC, bored, ported/polished heads, 9.5:1 dished pistons, Lunati 480/292 cam, electronic ignition, Edlebrock Performer intake, tricked out Rochester 850CFM Quadrajet, long tube headers, Flowmaster 40's, TH350-C with lock-up switch, 2800 rpm stall, shift kit, custom driveshaft, stock GM 12- bolt rear with Auburn Pro Series limited slip 3.73's, 2" drop spindles, 2" drop rear coils, track bar kit, front/rear stabilizers. 1999 30th Anniversary Trans-Am Coupe #1494 - M6, Flow-tech cut-out, Flowmaster, free mods. One of 292 coupes with M6 and in-dash CD.
Check out my Blazer at http://community.webshots.com/user/wdsteeves.I put in a 3 point seat belt from Mothertruckers.I mounted the loop to the upright of a modified P/U roll bar ,the recoil mounted to the stock hole and for the short portion of the seat belt I used a couple of 2x2 pieces of aluminium.They mounted to the existing holes as well.It turned out A-1.Any questions,glad to answer them. Good luck
Member since 2000
http://www.crowenterprizes.com/ here you go,
and also http://www.simpsonraceproducts.com/ ------------------ Mechanic @ California Concept Britney: 1970 2wd K/5 Blazer (Frame up) Jessica: 1967 2wd SWB (pops daily driver) Helga: 1972 4x4 3/4ton LWB (my daily driver) AIM:Alexmart1 Mountain View, Cali [This message has been edited by alexmart1 (edited April 23, 2002).] |
