Old 10-07-2006, 01:29 PM   #1
69CvyPickup4x
69CvyPickup4x's Avatar
gas tank line
what type of line does everyone think is the best to run down the frame rail for the new rear gas tank.. I wanted to run a hard line or do you think it would be fine to just run a braided line or?? Thanks
69CvyPickup4x is offline   Reply With Quote
Old 10-07-2006, 03:25 PM   #2
cdowns
cdowns's Avatar
Re: gas tank line
you can buy a 25foot coil of 1/4inch steel line for a fraction of the cost of braided lines both will supply gas to the engine// on an everyday driver those braided lines trap the dirt real good and are impossible to clean// all you need is a couple of fittings and a flaring tool plus a few tubing clamps to hold the line in place
Old 10-07-2006, 04:17 PM   #3
Billla
Billla's Avatar
Re: gas tank line
Run hard lines wherever you can.
I tapped into the original hard lines for my braided lines. I agree they're virtually impossible to clean, so they have to be KEPT clean...not easy on a daily driver unless you're a neat freak (like me
Billla is offline   Reply With Quote
Old 10-07-2006, 04:19 PM   #4
byrd
Union Electrician
byrd's Avatar
Re: gas tank line
I bought the stock lines from pump to tank and just cut the bend off the end where it would turn towards the tank in the cab. Then I bought a compression coupling and a 6' piece of tubing at my local auto parts store and changed over to rubber from the rail near the tank to the tank itself. I only had to use about 2 1/2' of rubber fuel hose to get to the tank.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 10-07-2006, 05:07 PM   #5
msgross
msgross's Avatar
Re: gas tank line
So running all rubber (approved for fuel of course)from sending unit to pump isn't a good idea? if not please explain, what if it's tied to the inside of the frame and protected?
msgross is offline   Reply With Quote
Old 10-07-2006, 06:18 PM   #6
qksilver
Re: gas tank line
no it isn't. You always try to run as little rubber line as possible. Hard line holds up better, to road trash, heat, vibration etc. Think for a minute, which would you rather have running down the length of your truck holding a flamable liquid,exposed to what is lying on the road
qksilver is offline   Reply With Quote
Old 10-07-2006, 07:07 PM   #7
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: gas tank line
NHRA mandates 12 in or less of rubber line for a reason.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-07-2006, 07:36 PM   #8
BowTieMan
BowTieMan's Avatar
Re: gas tank line
I used two sections of 3/8 brake line from auto zone. I can't remeber what length though. One section hookes to the original line under the cab with a compression fiting, then there is my fuel filter and rubber hose to connect the two, then a 3 in. section conection to the tank. The line was straight with two fittings and flares allready on both ends.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 10-07-2006, 07:36 PM   #9
msgross
msgross's Avatar
Re: gas tank line
NHRA also mandates roll-cages, I won't be doing much drag racing in my truck though.
I agree with using as little rubber line as possible. Guess I need to look into some steel before I do my tank install.
Old 10-07-2006, 11:38 PM   #10
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Re: gas tank line
I put an LT1 in mine so I needed the return line as well. I went to the local yard and pulled the fuel lines, filter and filter clamp from a Caprice. They gave them to me. (I did buy a bunch of other stuff). Changed the filter of course, but it is tough stuff, easy to run, and withstands high pressure.
low'n slow is offline   Reply With Quote
Old 10-08-2006, 07:40 AM   #11
centsless
sufficiently talented fool
centsless's Avatar
Re: gas tank line
I used 3/8 steel line that I purchased in a roll of 25 foot. A slight flare at the ends ensures the rubber hose will not slide off. msgross PM me if you need some line. I will be going to Shartlesville,PA next weekend. Going thru York and Harrisburg I'm sure we could meet up.
Bob
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
