Old 10-07-2006, 07:36 PM   #1
CMars45000
CMars45000's Avatar
Who has installed a trailing arm reinforcement kit???
Just curious if you welded the whole thing or stitch welded it like 3" of bead and 3" no weld...?
Project Family Values Build Thread
Vehicles/Projects:
-1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon...
Pleasure in the job puts perfection in the work.
-Aristotle
CMars45000 is offline   Reply With Quote
Old 10-07-2006, 08:18 PM   #2
qksilver
Re: Who has installed a trailing arm reinforcement kit???
The longer the welds the stronger it will be
qksilver is offline   Reply With Quote
Old 10-07-2006, 08:21 PM   #3
72CSTC5
72CSTC5's Avatar
skip the reinforcement kit and just run a few stitches between the trailing arm halves.
72CSTC5 is offline   Reply With Quote
Old 10-07-2006, 10:40 PM   #4
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
I fully welded mine. Weld 4", skip 4", weld 4", skip 4", and so on. Then come back and weld the rest.
I'm not sure what a kit cost, but I just bought 1/8" flat bar. Cost about $20-$25.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 10-07-2006, 11:20 PM   #5
CMars45000
CMars45000's Avatar
Yeah I welded mine on today...I was just curious how others had done it...
I went full bore and welded the whole thing in addition to three 6" welds down each "valley" between the beams...
I just bought the kit from early classic because it is hard enough to find the time to weld the darn thing on let alone get down to buy some steel.
Vehicles/Projects:
-Aristotle
Old 10-08-2006, 01:09 AM   #6
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
Just do what the PO of my truck did, box the whole thing
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 10-16-2006, 02:12 PM   #7
jodydewey
Junior Member
jodydewey's Avatar
I was always told when you are welding large items you are not supposed to weld them all the way down. If a crack forms it will go the length of the weld. If the welds are separated by a gap when a crack forms it stops on the one weld. Just my two cents....
Jody
jodydewey is offline   Reply With Quote
Old 10-16-2006, 02:17 PM   #8
glock35ipsc
No so...... the main reason for not welding the complete length is heat. Too much heat will warp stuff. Weld in segments, then come back and fill in th empty spots. A full weld is more desirable.
We weld 1/2" to 1' steel all day, full triple-pass welds, and we weld in 5"-6" beads at a time. Then once completely welded, we come back and weld in the empty spots.
Bob
