Old 10-08-2006, 11:39 AM   #1
matt_field
matt_field's Avatar
67 wiring interchangable with 72 wiring?
i have a 67 chevrolet pickup im restoring and i have 72 warning light dash wiring im putting in it... for the engine bay harness it is a 67 wiring, is this interchangeable? also i think the 67 wiring i had came out of a truck that had gauges instead of warning lights.. i hope this makes since
1971 k5 blazer 80k mike survivor
1972 3/4 ton 4wd Cummins 12v
1967 swb 2wd 427bbc
1968 4wd shortbox
1971 Cheyenne swb k10 unrestored
1971 Cheyenne super 40k 402bb survivor
1967 Chevy k10 (first truck)
1968 L78 camaro survivor 18k miles
1969 z28 survivor 60k miles
1969 z28 survivor 39k miles
1969 z28 rs survivor 80k miles
matt_field is offline   Reply With Quote
Old 10-08-2006, 05:31 PM   #2
matt_field
matt_field's Avatar
Re: 67 wiring interchangable with 72 wiring?
anyone? someone has had to do this before
1967 swb 2wd 427bbc
1968 4wd shortbox
Old 10-08-2006, 06:46 PM   #3
john
member #16
john's Avatar
I'll try to help since no one else has. You would be better off using matching harnesses. The guage harness will have ammeter wires in the engine loom amd a warning lamp harness would have temp amd oil pressure light wires. Then the it would be the same on the dash harness. These are just two, there might be more. There is a diagram on GMC Pauls site in the tips section which shows the wire positions in the cluster plug for guage and lights. I imagine it can be done with some rewiring.
john is offline   Reply With Quote
Old 10-09-2006, 12:28 AM   #4
Rod
kinda depends how good you are at reading wiring schematics also.
there are difference on inside wiring harnesses besides making the guages works, you could have reverse lights or neutral safety issue depending on the inside harness you have from the 72.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 10-09-2006, 11:10 AM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
The key switch is in the column on the 72 and in the dash on the 67 so wire lengths are gonna vary as well. I think the engine compartment is the same. The schematics are great for showing where the wires go, but they don't help much for locations of parts and lengths of wires. It is possible to convert the wiring, but it will take some effort.The dashes are different as well, and will require quite a bit of rewiring if going from idiot lights to gauges.
There are threads on the forums showing how to do this and several guys have done it so they may be of more help.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
