Old 10-08-2006, 01:06 PM   #1
77-383 Step
any body use drop leaf springs?
Hey, newbie here. I have been following this site for a year now and I'm finally getting close to dropping my truck. My truck currently leans to the passenger side, so as part of my drop I wanted to replace the springs. I will use 2 1/2" spindles and 1 1/2" coils in the front. But I was thinking of using lowing springs in the rear. Western Chassis sells a 4/6 kit with these. Is this worth it? everyone else seems to just use a flip kit? If any one has tried it, would you recommend it? or should I just flip and see if me truck still leans? I don't ever plan on hauling any loads. Sorry if this is to wordy, just trying to include everything.
Thanks for any advice
77-383 Step is offline   Reply With Quote
Old 10-08-2006, 01:43 PM   #2
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Re: any body use drop leaf springs?
Yeah, flip kits are popular. They are convenient and relatively less inexpensive. A few have used lowering springs only to resort to a flip kit in the end. With a flip kit, you won't have to mess with the shackles or hangers to get the 6" drop.
You could get under the truck and measure the clearance between the axle and the frame rail on both sides. If they're the same, you can go with a flip kit without replacing the springs. If not, you can still go with a flip kit and add a spacer to make up for the difference.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 10-08-2006, 02:04 PM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I have the WC drop leaves. I have had no problems with them, but I only wanted a 4 inch rear drop.
I think if I were in your situation I would want to be sure of the reason for the lean before making any decisions. Make the measurements boxrodz recommended and go from there.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 10-09-2006, 10:28 AM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I agree, find out why you are leaning. I
I have Chisholm rear 6" dropped springs, that I had custom built. The truck won't ever carry anything though, since he built them as we discussed so it would handle not haul.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
