Old 10-08-2006, 11:36 PM   #1
corkscrew
Relocation of the gas filling location.
Currently the filler cap is behind the liscense plate and i am looking to move it to inside the bed. If anyone knows what is needed for the conversion please let me know. Thank you in advance.
corkscrew is offline   Reply With Quote
Old 10-09-2006, 09:13 AM   #2
see ten
WTB this ad
see ten's Avatar
Re: Relocation of the gas filling location.
Is it not filling well behind the plate? I haven't ever seen anyone put it there before. Post some pics of what you're running now.
see ten is offline   Reply With Quote
Old 10-09-2006, 10:52 AM   #3
corkscrew
well i cant post pictures as my digital camera has been sent for fixing. But yeah you just flip down the liscense plate and screw off the gas cap. I want the gas cap in my bed as i have seen in numerous trucks in classic trucks magazine.
Old 10-09-2006, 10:55 AM   #4
corkscrew
Kind of like what this guy has.
Old 10-09-2006, 03:31 PM   #5
matthufham
i had this setup here and gas would not flow into the tank, because it had to go uphill slightly, to get over the frame.. i ended up moving it to a higher spot on the wheelwell but i'm looking for a better way to do it. i can't imagine the gas flowing from the lower spot of the license plate into the tank.
matthufham is offline   Reply With Quote
Old 10-09-2006, 05:15 PM   #6
jimmydean
jimmydean's Avatar
I thought about behind the plate (like a late 70's Camaro), but I have my air tank there, so that wouldn't work.
jimmydean is offline   Reply With Quote
Old 10-09-2006, 07:19 PM   #7
extd56
extd56's Avatar
The one in my 69 works great but does not look the best.
extd56 is offline   Reply With Quote
Old 10-09-2006, 07:45 PM   #8
corkscrew
I am really just looking for the parts to make it like the picture i had. I think i need a neck and a cap??? Where can i get those?
Old 10-09-2006, 08:21 PM   #9
clay68c10
clay68c10's Avatar
A lot of people use boat stuff.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 10-09-2006, 08:28 PM   #10
msgross
msgross's Avatar
I think the gas cap looks okay but your wood bed mod might need some work! just kidding.... I am still working on my fill spot too.
CPP has a flip door with a neck built into it. I am thinking it looks easy for my skills (none)....
http://www.classicperform.com/Store/...rucks/CPTD.htm
http://www.classicperform.com/Store/...cks/CPFFKB.htm
msgross is offline   Reply With Quote
Old 10-09-2006, 09:09 PM   #11
corkscrew
So nobody has seen the one that is on the truck i posted? thats too bad i wanted to find that one.
Old 10-09-2006, 09:22 PM   #12
qksilver
Do a web search, I have seen ones like that in a few of the catalogs, can't remember which ones
qksilver is offline   Reply With Quote
Old 10-09-2006, 10:16 PM   #13
extd56
extd56's Avatar
The piece of plywood hides the hole in the bed from the fifth wheel the Po had installed that I plan to fix.
Old 10-09-2006, 11:17 PM   #14
QKENUF4U
QKENUF4U's Avatar
heres mine....... i had to relocate it to the back side of the wheel well since it wouldnt fill uphill
the last two pics are of a filler i have for sale. couldnt use it since it was to long.
QKENUF4U is offline   Reply With Quote
Old 10-09-2006, 11:25 PM   #15
HuggerCST
HuggerCST's Avatar
Try defender.com and search for deckfill. I just ordered #303323.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 10-10-2006, 12:11 AM   #16
corkscrew
This is the cover i want. I just want to know wat i need to complete the setup.
http://www.classicperform.com/Store/...Trucks/PFD.htm
Old 10-10-2006, 12:12 AM   #17
Russell
Professional Grade
Russell's Avatar
I put mine into the back of the wheel tub. I used exhaust pipe to run from the filler neck down and out of the wheel tub, then used rubber tubing from there across the frame rail, and into the tank.
While I doubt I'd have problems with rocks going through the pipe, or rubbing if I loaded the truck up, it really doesn't look all that great from under the wheel well, and chances are the inspections dude is gonna fail me on it if I leave it that way.
I'd like to do something similar to what matthuffham did, except use the little box he made as a place to run the hose between the two box side skins, and have the filler door on the inside wall of the box. Then it is out of the way, and doesn't run the risk of being hit by anything, or getting failed by the inspection guy.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 10-10-2006, 08:58 AM   #18
wibilly
wibilly's Avatar
i did the side marker fill on mine. i don't know why anybody would want it in the box floor, but then again i use my truck for a truck but still can't see draging the hose over the paint or opening the tailgate to fuel the truck. but this is just my opinion i'm sure others have their reasons for doing it other ways
common sense isn't so common anymore
wibilly is offline   Reply With Quote
