Old 10-10-2006, 01:33 AM   #1
jimmydean
jimmydean's Avatar
No key and the wheel is locked!
I found a possible '77 short step project truck I was going to buy for a friend of mine. When I called on it, the owner said her ex had lost the key, but she can start it without it. When I asked when I could take a look, she said it starts without the key because a friend took apart the column, but the wheel is locked, so it can't be driven.
I know on my old Toyota 4x4, you could pop the whole ignition cylinder out and it would start with a screw driver. Don't these trucks work the same way? Is there a way to pull the whole thing out and replace with a new lock set? How?
Thanks.
jimmydean is offline   Reply With Quote
Old 10-10-2006, 01:38 AM   #2
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Re: No key and the wheel is locked!
It would be best to go ahead and replace the lock ignition by following this site's steps. http://www.chevyasylum.com/column/tiltcol.html You may be able to start with but you have to turn the cylinder to disengage the lock on the sprocket.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 10-10-2006, 02:41 PM   #3
84 400
Sb 400 club
84 400's Avatar
yeas remove it as said in the artical. you may use a steering wheel puller to make it easyer.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 10-10-2006, 08:00 PM   #4
edman87
junk collector
just pull the wheel and remove the lock ring to teast everything out.
'87/89/76 K5 in progress
'99 K2500 short crew
'91 camaro rs
'98 jeep tj
'52 willys cj3a
edman87 is offline   Reply With Quote
