Old 10-10-2006, 02:11 AM   #1
Brad
Out of the carpool lane.
Brad's Avatar
Question Is there any good way to clean spark plugs?
I recently bought a new 1403 carb and want to make sure everythings adjusted right for my engine. However, my sparklers are fairly new and being the cheapskate I am, I want to clean them and put them back in to gauge if I'm running rich or lean. Is there any way to effectively clean a spark plug in order to do this or do I have to buy brand new ones?
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 10-10-2006, 02:15 AM   #2
Aarons72s
Re: Is there any good way to clean spark plugs?
Cheap way I just spray on carb cleaner and a brass wire brush. Done that a few times other than that buy new plugs.
Aaron
Aarons72s is offline   Reply With Quote
Old 10-10-2006, 02:33 AM   #3
'68OrangeSunshine
'68OrangeSunshine's Avatar
AAron's right, but sometimes you might also want to dress the center electrode with a very thin ignition file taking off just a little metal to get a clean surface. (This doesn't work w/ platinum, I'm told) Make sure your gaps are perfect. Check the threads for signs of crossthreading.
Old 10-10-2006, 05:20 AM   #4
junkyardjohn
junkyardjohn's Avatar
WELL... BACK IN THE OLDEN DAYS (I'M TALKIN 35 YEARS AGO) WE USED TO SAND BLAST THEM. A GAS STATION NEAR ME (YES THEY DID MORE THAN JUST PUMP GAS & SELL SODAS) HAD A LITTLE FIXTURE' WITH A SMALL BAG OF SAND ON IT THAT YOU PLUGGED INTO AN AIRLINE & SCREWED A SPARK PLUG INTO. IT WOULD BLAST THE ELECTRODE END CLEAN. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 10-10-2006, 06:48 AM   #5
cdowns
cdowns's Avatar
i've still got my little sparplug blaster that i got from jcwhitney its a handy little tool/ i think they may still sell them??
Old 10-10-2006, 07:10 AM   #6
mbgmike
they are still sold
mbgmike is offline   Reply With Quote
Old 10-10-2006, 09:22 AM   #7
TruckinDaddy
What's that funky smell?
TruckinDaddy's Avatar
I bought one for less than $10 at Harbor Freight last year.
Mike S
68 C10 Long Step (Pretending to be a Long Fleetside) Grandpa's Farm Truck
3 on the tree, 307, No power brakes or steering
Factory Options - HD rear spring and Ammeter/Oil Gauges
My truck blog
My Car Domain page
TruckinDaddy is offline   Reply With Quote
Old 10-10-2006, 12:41 PM   #8
70short
I also bought one from Harbor Freight for under $10. It is A handy tool for around the shop!
Gary
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 10-10-2006, 12:45 PM   #9
71SWBChevy
Post Whore
71SWBChevy's Avatar
So is it ok to sandblast a plug like that? It won't hurt it? Our lawnmower is really bad about fouling plugs so that might be something that would be nice to have. But currently just use the bench grinder with a wire wheel on it, works alot faster than the hand brush.
Drew
'71 Chevy 350/TH350 Hugger Orange
Currently just a rolling frame, body work soon to follow!!!
Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927
Daily Driver: 1997 Chevrolet S-10 with more gears than pistons
71SWBChevy is offline   Reply With Quote
Old 10-10-2006, 03:42 PM   #10
Orange
Licensed to Thrill!
Orange's Avatar
I was thinking - uh-oh - he's fouled a plug somewhere and can't get one of the same. Happened to me one time. I have to run the shorty header plugs, and there weren't any readily available at midnite...
I just had to run the hound out of it to get it hot - it "unfouled" luckily.
Riding ATV's/dirtbikes you foul a lot of plugs - our method was always the same. Find a woman with a finger nail file and go town. Hey - it'd get you back on the trail. Then we all looked like a bunch of manicurist with our fingernail files on the trails.
I suppose my response isn't respected well. Not the best way to do it, I know.
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 10-10-2006, 07:14 PM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Just make sure you clean the plug out real good... don't want sand to fall down into the engine.
Old 10-10-2006, 08:10 PM   #12
BarryB
BarryB's Avatar
Hey just a little word to the wise. I bought my spark plug blaster from Harbour freight also. Works great by the way. What I was wanting to say is, They don't use sand as an abrasive. I believe it is aluminum Oxide.when I purchased mine it came with a small bag of this stuff. But still like Longhorn Man said you should use an air nozzle and blow it out before you put back your motor.
BarryB is offline   Reply With Quote
Old 10-10-2006, 08:12 PM   #13
crm318
Alright Alright Alright
crm318's Avatar
just this past weekend, i cleaned a set of plugs with the gel aircraft paint remover on them. it ate every bit of oil and carbon off and they looked brand new.
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 10-10-2006, 11:39 PM   #14
Longhorn Man
Now, with all this said... I generally don't bother. Plugs are what... a buck and a half each? if I'm gonna go through the hassle of removing plugs... I generally screw new ones in.
Old 10-11-2006, 12:10 AM   #15
ERASER5
ERASER5's Avatar
New plugs are best. No doubt. On the other hand, those little sand blasters are quite handy for lawn mowers, weed eaters, and the like. If you already have a spark plug blaster, use it. If you have never used one, the blaster has a two position switch. One way blasts the plug with media and the other way blows it off. The plug should come out very clean.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 10-11-2006, 02:04 AM   #16
hogrocket
Junior Member
I've always just ran them through the wire wheel mounted to a chuck of my drill press. Works quickly and leaves the electrode looking like new.
hogrocket is offline   Reply With Quote
Old 10-11-2006, 01:31 PM   #17
Brad
Brad's Avatar
Yes, after I wrote this I came to the same conclusion and figured that once I have my carb adjusted correctly and can make sure using the new plugs, I can clean the electrode off the old ones(if a bit yucky) and throw them in again knowing that everything is good to go. Besides, I only have to buy 6 anyway!
Thank you all for your suggestions!
