94 Guage Readings?
I just bought this 94 X-cab with 174K The test drive was fine everything worked well, it had a small leak on the radiator (pin hole leak). I drove it all weekend and other than the leak on the radiator everything was good. Well last night on my way home from work the oil pressure gauge shot up to 80 I pulled off to the side and checked the oil, it was good. I then started it back up took off, the guage now was 3/4 the way at a stop (during idle) it is halfway. It also will jump around at times from 80 to 3/4 the way and sometimes even halfway during driving. I then thought maybe the guage(s) are bad or maybe even the sending unit as since I have that pinhole leak the Temp has never gotten over 1/4 the way.
What do you guys think?
http://www.adicustoms.com/ |
| Bookmarks |
