10-10-2006, 11:31 PM | #1 |
327 cid small block out of a Massey-Fergison
i was wondering if anyone by chance had the specs. or knows where i could get the specs. for a 327cid small block chevy engine out of a Massey-Fergison combine.....i have identified it already as a '64-'67 2 bolt main 327 with 75cc heads, and know that it has a forged steal crank shaft......what i am mainly looking for is what horse it is and weather or not i can just slap a new intake on it and run it... as it ran before it was pulled and bought for $100 this summer...
here are the casting numbers off of the block...bellhousing (serial number)3858174 (front of the block behind and below where the alternator should be) e0531zap
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you." '84 chevy half ton short box 2wd, 67,000 actual miles '03 chevy 1500 HD crew cab 4x4 standard box, 6.0L |
10-11-2006, 08:47 AM | #2 |
Slots go on anything!
Re: 327 cid small block out of a Massey-Fergison
With heads like that, I wouldn't expect much. Those were built to be dependable, not have huge HP. Are you sure the heads have that big of combustion chambers? I thought the biggest ones during the smog days were 72 cc, but I could be wrong. I would try to find a later model head, with hardened valve seats, to bolt up and go. Maybe a later model set of 305 heads with smaller chambers would do what you need?
10-11-2006, 11:42 AM | #3 |
RIP Mr Ron
What are your plans for this engine. Do you plan a rebuild before putting it in a vehicle or just put what you have to on it to make it run?
Ron (Mr Round Tuit) Be kinder than necessary, for everyone you meet is fighting some kind of battle TN Message Forum TN Facebook Group SETN Truck Show My Photobucket |
10-11-2006, 01:20 PM | #4 |
If the heads haven't been redone since unleaded gas was being used would unleaded be safe or haed on the heads? I have just always heard that.
10-11-2006, 04:37 PM | #5 |
Sb 400 club
unleaded will no luberucate the seats and guides. many people have there own views on how the unleaded gas will effect them. it was on a combine so would smog even matter?
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
10-11-2006, 11:27 PM | #6 | |
Stu- 1981 GMC Sierra Classic LWB 355- original 2 bolt block, 10.2:1, vortec heads, Comp XE268 cam, built by self in 1992 700R4-2000 stall with lockup, shift kit, Corvette servo 3.07 open diff- I need a 3.73 posi! 2nd owner since 1986 - 388,000 km and counting. 100k by the first owner and the rest by me. |
10-11-2006, 11:32 PM | #7 |
Commander Taco Bello
he's thinking about putting a pair of 60cc corvette heads off of a 283 on to it. assuming they pass the crack check.
and a 4bbl intake/carb
10-12-2006, 01:12 AM | #8 |
Most Chevy heads were 64 cc until 1971 when they started lowering the compression ratios. All 327's had forged steel cranks as far as I know and read until 68 when they went with the larger mains and rods. John Deere also used the 327 V8. The cam is probably pretty tame for a street engine but thats easy to change along with the intake/carb and maybe the heads.
72 Chevy C20, SOLD (Dang it.) 09 Challanger RT six speed in all black. 74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power. 73 C10 long bed, 350/350 combo, nice shape. |
10-12-2006, 02:19 AM | #9 |
67-72 parts finder
i'd say its a 250 hp engine or maybe less, but thats just a guess go to mortec.com and look up the casting numbers if you'd like
1969 chevy shortstep 2wd (under construction) 1981 chevy scottsdale lwb 2wd (parts chaser) 2004 pontiac gto (daily driver) 2004 pontiac grand prix gt (the ol ladys car) 1985 chevy short wide 1970 chevy c10 lwb (another parts rig) 1969 gmc lwb (rainy day project) 1968 chevy lwb c10 250 I6 3 spd (soon to be swb) |
10-15-2006, 09:47 PM | #10 |
okay...i didn't realize that i would get replies so fast, but here goes.....i have identified the block as a '64-'67 327, and also the heads...yes the heads are a 75cc chamber, not 72cc....as they are also a presmog engine....as for the intake and carb...they are hitting the road and will get a factory q-jet intake off of a newer motor....something about the quater size butterflies in the 2 barrel carb. tells me that the motor wouldn't be worth a crap in a car....i am planning on putting a pair of 60cc heads on it from a 283cid small block as they also put them on some 327's.....i am looking for a (no laughing) Chevette body to put it into....or i might just put it in my 4x4. i'm not for sure yet....and after this next srping i plan on getting ready to tear the motor down completely and make an 8,000rpm motor out of it...and yes it has a forges steal crank in it....keep in mind that while they put these engines in combines that they have never been ran much over 3,000 rpms....but it should make for a heck of a sleeper.....oh, and it is atleast 300hp
10-15-2006, 09:51 PM | #11 |
oh, and as far as the leaded vs. unleaded......if it doesn't have the hardened valve seats in it....it is best to run leaded because it keeps the valve seats lubed and cooler so that they don't distort......if you don't run a lead additive it will eventually ruin the seats and you loose compression
10-16-2006, 11:46 PM | #12 |
The lead is supposed to lubricate the seats better, nothing to do with cooling. You can have hardened seats put in the exhuast valve positions to prevent valve wear to. The combine may not have turned the engine over 3 grand but it had to pull a heck of a lot of weight and run a lot of machinery at the same time. Take the heads off and see what the cylinders look like and check the main and rod bearings.
10-18-2006, 02:16 AM | #13 |
Sb 400 club
my dad had a chevette and it was one of the best cars he ever owned! he useed to drive it up in the montains of CO with no probles
10-18-2006, 02:33 PM | #14 |
No No
Lubrication and cooling go hand and hand.
This engine will be a stock production low output engine the way it sits. They did use larger combustion chamber heads and in some id/ag aplications you may also find pistons with a huge "tub" area in the center of the piston kinda like a super dished piston. This was also another attempt to lower compression for the various grade fuels used world wide, help lower operation temps and extend service life. The valves are small as well, off hand I dont remember exact size but there dang small.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
10-18-2006, 05:11 PM | #15 |
for now i am just planning on getting it running again as i know it ran fine in the combine....well for 5 seconds anyways...the throttle was stuck and it imediatly kicked up to 1,500 rpms...which on a motor that has been sitting isn't good...but it didn't misfire, huff smoke, or rattle.....and boy did it start up good...but like i said i just want to get it running for now and in the spring i plan to tear it down and go through every inch of it....clean and cracked and machine work...then rebuilding it with alot of new parts....
