Old 10-11-2006, 08:44 AM   #1
alpar80
body panel gaps
In the daunting task of fitting and aligning new floor pans and panels I have noticed that I have gaps in the metal where I cut and fit the new panels, large enough that I cannot weld a bead there. The gaps arent much more than 1/16 of an inch wide, what should one do to fill the gap, caulking ??
alpar80 is offline   Reply With Quote
Old 10-11-2006, 09:42 AM   #2
72CSTC5
72CSTC5's Avatar
Re: body panel gaps
You can close up a 1/16th of an inch with a welder if you take your time and work back and forth and side to side.
72CSTC5 is offline   Reply With Quote
Old 10-11-2006, 10:16 AM   #3
alpar80
Re: body panel gaps
What if not??
Old 10-11-2006, 11:41 AM   #4
sleepyboy
'69 Step
Re: body panel gaps
Do you have spare sheet metal you can use to bridge the gap and weld in on both sides??
sleepyboy is offline   Reply With Quote
Old 10-11-2006, 12:36 PM   #5
72-stomper
Re: body panel gaps
duct tape
72-stomper is offline   Reply With Quote
Old 10-11-2006, 12:42 PM   #6
alpar80
Re: body panel gaps
Briging the gap with sheetmetal can work. It is wicked hard to be precise with cutting and fitting.
Old 10-11-2006, 01:16 PM   #7
67ChevyRedneck
67ChevyRedneck's Avatar
Re: body panel gaps
That can be somewhat cured by cutting the panel slightly large, test fit, grind down areas that are too big, test fit, grind, test fit, grind. It's a pain in the ass but it worked for me. My very first welding job was on this a few months ago:
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-11-2006, 03:20 PM   #8
alpar80
Re: body panel gaps
Damn that looks sweet.
Old 10-11-2006, 03:21 PM   #9
alpar80
Re: body panel gaps
After the weld/grinding, what did you use? Metal prep, rust encapsulator, body filler, then prime and paint?
Old 10-11-2006, 03:46 PM   #10
67ChevyRedneck
Re: body panel gaps
Basically, yes. I love rust encapsulator. Don't use it on a hot day though, that crap dries FAST! Thanks for the props. There was a long time between pic one and pic two Unfortunately (as you can see) I had a rust free fender but it was beat to crap by the previous owner/owners. I beat it out the best I could. In case your interested here's one from underneath. I haven't installed the clamps or vent hose yet (I'm currently trying to find where I put it )
Jesse James
Project "On a Dime"
Old 10-11-2006, 04:39 PM   #11
alpar80
Re: body panel gaps
hey that looks great, you took the spare tire mount out and placed a tank back there, not a bad idea. I used some rust encapsulator from Car Quest, I want to get some from Eastwood, but cant wait too long, I guess it's all the same. I have some spots to sandblast, lots of work. Looks good tho.
Old 10-11-2006, 04:40 PM   #12
alpar80
Re: body panel gaps
BTW is that a piece of tailpipe used for a fuel filler?
Old 10-11-2006, 04:49 PM   #13
67ChevyRedneck
Re: body panel gaps
No, not the main piece that you see. It is stock '96 Silverado fuel filler neck. The diamater on the silverado filler neck was much larger than the blazer tank filler neck, so I did use some muffler pipe from a parts store to make up the difference in the filler neck size using 2 different sized rubber fuel hose. Hope that makes sense??? There is a lot of detail and pics in my "build thread" in my signature.
Jesse James
Project "On a Dime"
Old 10-11-2006, 05:30 PM   #14
jaros44sr
jaros44sr's Avatar
Re: body panel gaps
Sometimes I have placed a piece of copper behind the gap, sorta supports the molten metal so it doesn't drop out. Worked for me!!
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-11-2006, 07:26 PM   #15
High Speed low Drag
High Speed low Drag's Avatar
Re: body panel gaps
Turn your wire speed up and amperage down. Not too much. Practise on scap first. With short bursts you can build up enough metal to weld the two together. Do small sections at a time. You want to hear it "POP" as opposed to "sizzle".
High Speed low Drag is offline   Reply With Quote
Old 10-11-2006, 07:32 PM   #16
Rokcrln
Rokcrln's Avatar
Re: body panel gaps
Now if you are using a wire feed welder than a 1/16" gap is just about right. When using the wire feed you want a gap in your metal the same thickness as the metal that you are welding. Practice, Practice and then more .....
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 10-11-2006, 07:36 PM   #17
shortbed70
shortbed70's Avatar
Re: body panel gaps
Use a carbon block or a piece of brass on the back side and you'll be able to fill the gap. We use them at work when welding odd angles that or band saw won't cut.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
