Old 10-11-2006, 11:36 AM   #1
jpkerley
Active Member
ignition help, I think
A couple of months ago I replaced the ignition switch in my truck b/c when I turned it it would do nothing, no click nothing, but battery was hot, so put in the new ignition and it worked ok for a while, now i cant get it to turnover, no click, nothing, no buzz either, battery is hot, is this a ground problem, and pointers would be great.
jpkerley is offline   Reply With Quote
Old 10-11-2006, 11:48 AM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: ignition help, I think
When nothing is coming on(check head lights) then start at the battery and work your way up looking for a bad connection.If you have lights then try this
With the truck in "park or neutral" use a screwdriver to jump the solenoid, go from the "Bat" terminal(+ from the battery) to the "Sol" purple wire. this will bypass all wireing in the dash. If this doesnt work then you have either starter or battery connection troubles.
sneakysnake is offline   Reply With Quote
Old 10-11-2006, 12:07 PM   #3
jpkerley
Active Member
all lights winshied wipers etc are working
Old 10-11-2006, 02:28 PM   #4
sneakysnake
Jump the starter that will tell you its working.Is it an "automatic"check the neutral switch on the column.
Old 10-11-2006, 02:33 PM   #5
jpkerley
Active Member
yeah its an auto, what do you mean by the neutral switch on the column?? I thought the neutral safety switch was on the tranny.Thanks
Old 10-11-2006, 02:41 PM   #6
sneakysnake
It should look like this.
Old 10-11-2006, 03:19 PM   #7
jpkerley
Active Member
thanks, is there any way to check it besides replacing it?
Old 10-11-2006, 03:30 PM   #8
sneakysnake
Use a jumper on the purple wire to bypass the switch
Old 10-11-2006, 05:43 PM   #9
Aarons72s
Hay I used the jumper on mine to fix it permently. I hate those things. I know there there for safety but I could care less. IT is up to you if it is your neutral safety switch. Replace it or bypass it.
Aaron
Aarons72s is offline   Reply With Quote
Old 10-11-2006, 06:13 PM   #10
70GMCer
70GMCer's Avatar
Agree....the purple wires that are connected to that switch, tie those together and try to start.....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
