Old 10-11-2006, 11:54 AM   #1
68Stepbed
68Stepbed's Avatar
Question Best way to clean engine?
My chassis is mostly complete, and next on the list is cleaning and repainting the engine. I will be installing a new cam, lifters, timing chain, and roller tipped rockers, so the engine will be partly tore down. What is the best materials and methods to clean and paint the engine while it's still in long block form? I read the article in Classic Trucks, but it wasn't good on detail.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 10-11-2006, 12:04 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Best way to clean engine?
I power washed mine than used lots of Castrol Super Clean, then used a toothbrush and more Super Clean, then used the tooth brush and paint thinner. Lots of scrubbing! Once good and clean I used the VHT high temp engine paint and it appears to be holding up very well.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-11-2006, 12:37 PM   #3
Billla
Billla's Avatar
VHT paint stripper CAREFULLY applied, then clean with a good water-based solvent (I like Super Clean too and as noted, lots of brushing Once you feel that it's clean, a good washdown with lots of water and then I prep them like I do for painting - I use a good pre-paint cleaner (I'm a PPG guy, but Eastwood PRE works pretty well). Finally, nice wet coats of VHT.
I haven't tried the POR or Eastwood engine paint but I plan to on an upcoming build of a buddy's engine.
Note that it might be a good time to take your die grinder and clean up some of the casting flash.
Send pictures! :-D
Billla is offline   Reply With Quote
Old 10-11-2006, 12:47 PM   #4
TP from Cntl PA
TP from Cntl PA's Avatar
If you can get your hands on one, a hot water pressure washer and some "Purple" or "Simple Green" cleaning solution works wanders.
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
Old 10-11-2006, 01:16 PM   #5
cdowns
cdowns's Avatar
i've always used kerosene with a stiff parts cleaning brush and wire brush for caked on stuff followed by a strong solution of spic-n-span with stiff parts brush or steel wool and a rinse of clear water with a hose or if available a pressure washer// a final wipe down with laquer thinner then prime and paint with paint of choice lately i've been using por15 engine paint or for a better variety of colors bill hirsh engine paint
Old 10-11-2006, 01:42 PM   #6
68Stepbed
68Stepbed's Avatar
Pressure washing will get water in my crankcase, wouldn't it?
Matt
Old 10-11-2006, 01:45 PM   #7
woodridge
woodridge's Avatar
I have found several cans of oven cleaner and a presure washer do wonders.Even better if it's a hot water washer. Do it in a well ventilated area, the fumes are a killer.
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline   Reply With Quote
Old 10-11-2006, 01:48 PM   #8
woodridge
woodridge's Avatar
I usually pull the pan anyway to do the gaskets, when you are done washing, oil everything and rotate the crank several times to relube the cylinder walls and cam, I've not had a problem yet and have done several this way.
Old 10-11-2006, 02:59 PM   #9
Luvlegs
Luvlegs's Avatar
You'd be suprised how fast you can clean up the block using only a toothbrush and lacquer thinner. I do it twice - the second time makes sure there is no oils left anywhere before prepping. Wipe it down with a clean rag/towel as you go along the second time.
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 10-11-2006, 05:14 PM   #10
chevyboy55
chevyboy55's Avatar
i use oven cleaner then a degreaser.
chevyboy55 is offline   Reply With Quote
Old 10-11-2006, 05:36 PM   #11
jimmydean
jimmydean's Avatar
I was going to use the orange clean oven cleaner and Castrol Purple with a presure washer. My truck is ghetto, so it's all about cheap and easy.
I will put a new motor in before I need to paint this one.
jimmydean is offline   Reply With Quote
Old 10-11-2006, 06:08 PM   #12
shifty
Questionable
shifty's Avatar
i used a straight pressure washer last time around. wound up ruining those clothes and was washing droplets of oil and engine gunk off my skin for a week afterwards. It did a damned fine job of cleaning that bad boy up, though. Probably should have soaked it in Simple Green first.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 10-11-2006, 07:02 PM   #13
watahyahknow
watahyahknow's Avatar
ovencleaner works good but can eat itself intoo aluminium when you leave it on too long , brakecleaner works good too dishwashingliquid and a lot of elbowgrease does the job to on just oil
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 10-11-2006, 07:47 PM   #14
arkracing
Weekend Warrior
I usually use 2 cans of "Gunk" Engine Bright - available @ Wal-Mart (It's basically kerosene)
Pressure wash (with the sprak plugs in & stuff the exahust holes with rags)
Rotate Motor, Drain Oil, Spray some oil into the cylinders - and rotate some more. - put the plugs back in.
Usually get most of the heavy gunk and crap off the motor - then I use a wire brush on a drill or by hand - whichever works best on the particualar area.
Then I spray it down with a couple cans of Brake Cleaner and blow it off good with the Compressor.
VHT Paint seems to be the best Rattle Can
POR15 is some sweet stuff - a pint goes a long way - even when spraying it
Bill Hersch - is a little thinner than POR15 and doesn't cover as well - I didn't even thin it.
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
