Old 10-11-2006, 06:30 PM   #1
stefan
New Member
73 spindles on 72
hey guys i was wondering i have a set of spindles that were made for a 73 but if i use them on my 72 someone told me that all i have to change are the outer ty rod ends,true or false.and also why do some people say its dangerous to run 3 inch drop springs in the front,thanks for the help
stefan is offline   Reply With Quote
Old 10-11-2006, 09:15 PM   #2
Aarons72s
Re: 73 spindles on 72
Yes you need a differnet outter tie rod end and a different adjusting sleeve. You also need to change 1 of the ball joints out, sorry forget which one upper or lower.
Aaron
Aarons72s is offline   Reply With Quote
Old 10-11-2006, 09:23 PM   #3
crazy longhorn
Fabricate till you "puke"
On a 1/2 ton truck, swap the upper ball joints & the outer tierod ends ...you should be good to go. I dont remember any issues with the sleeves, but on the 67-70, the sleeves are different IIRC.... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-11-2006, 09:25 PM   #4
classicchev
classicchev's Avatar
upper. inch lowered springs change all of the angles, and the amount of travel. Lots of guys run them with lowered spindles to give you 5-6 inch of drop
67- 72 Parts collecter
classicchev is offline   Reply With Quote
Old 10-11-2006, 09:30 PM   #5
stefan
New Member
but is it dangerous
Old 10-11-2006, 09:41 PM   #6
centsless
sufficiently talented fool
centsless's Avatar
I have 3 inch drop springs on mine, and it does fine driving up the road, but at slow speed it does not like very large bumps.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 10-11-2006, 11:19 PM   #7
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
trkklr77- as you know, there have been some rule changes within the past few months. In order to post for sale and want to but ads, you must be a subscriber. anyone may purchase from you however. By subscribing you get alot of new features, Ability to post Ads in the classified forums, Extra PM storage space, Bold Blue name, and A larger avatar. You can subscribe one of the following ways;
Using PayPal via subscription http://67-72chevytrucks.com/vboard/payments.php
or snail mail with a check/money order
Joshua Brady
PO BOX 7411
Midland, TX 79708-7411
Please include your board name on the payment.
trkklr77 is offline   Reply With Quote
