Old 10-11-2006, 11:41 PM   #1
XXL
Señor Member
XXL's Avatar
Question for the ultra-low
How much clearance in the trailing arm xmember did you add for your driveshaft?
As in...
XXL is offline   Reply With Quote
Old 10-12-2006, 12:07 AM   #2
bagged74
its just $$$$$
bagged74's Avatar
Re: Question for the ultra-low
As in...
I didnt add any....only to find out now that I have the body back on that I need to add about 1.5".....doh
bagged74 is offline   Reply With Quote
Old 10-12-2006, 01:46 AM   #3
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
not too much help here... Havent got the drivetrain back in yet
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 10-12-2006, 12:49 PM   #4
XXL
Señor Member
XXL's Avatar
Rats! You were two of the guys I was figuring would have the dimension I just picked up the above xmember, and want to raise and gusset that loop, but am not sure what's a reasonable distance. I've already got a 5" notch in the back of the cab, but can't find the actual needed height since the driveshaft bangs the stock xmember. Maybe I'll just go nutso and take it up to just under the seat.
Old 10-12-2006, 01:24 PM   #5
XXL
Señor Member
XXL's Avatar
Like this...
Old 10-12-2006, 01:44 PM   #6
SCOTI
SCOTI's Avatar
....Maybe I'll just go nutso and take it up to just under the seat.
That's what I would suggest. Take it up as high as the trucks floorpan will allow.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-12-2006, 05:27 PM   #7
thekid54
What if you cut the top off of the drive shaft loop on the stock crossmember to allow your driveshaft to come all the way up, then take your measurement? Or, are you trying not to destroy the stock one? Just a thought.
I'm making my own crossmember (my trailing arms are on the outside of the frame so I don't need the arm mounts) and will have the same problem. I have it mocked up right now and could probably give you a measurement. I'm running a 235 with the stock 3-speed, and a 12-bolt rearend. BTW my chassis is set up to lay frame.
thekid54 is offline   Reply With Quote
Old 10-12-2006, 07:29 PM   #8
gringoloco
A guy with a truck
gringoloco's Avatar
Yep. :yesnod:
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-12-2006, 10:14 PM   #9
XXL
Señor Member
XXL's Avatar
Floorpan? We don't need no stinkin' floorpan...
I'm already up into the cab. I'm trying to avoid the bandwidth required to install, measure, cut, remove, mod, reinstall... since I'm upside down in other projects at the moment If someone could get me a measurement from the center bottom of the xmember to the floorpan, that would help a lot. I think the dip in the center of the stock xmember is about 1" below the rest of the xmember... so I could take that measurement, subtract the 1" (since the ECE unit is flat there), then measure up from the floor to the bottom of the seat. Voila.
Digicam is dead, otherwise pics would make this easier for me to explain.
Old 10-12-2006, 11:00 PM   #10
PBFAB.COM
PBFAB.COM's Avatar
XXL-
There are a couple of pics in my dropmember thread that show how much of the floor needs to be removed for driveshaft clearance to lay frame on 29" tall tire. I have more on my computer at work I can get you tomorrow. It isn't much help as for an exact measurement for your x-member, but might be helpful?
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 10-13-2006, 09:17 AM   #11
XXL
Señor Member
XXL's Avatar
Hey, it helps a little
If I can just get a relationship between the measurement in this pic to the xmember location, I think that would do it.
Thanks in advance!
Old 10-13-2006, 01:24 PM   #12
gringoloco
A guy with a truck
gringoloco's Avatar
XXL- I've got 7" from the bottom of the framerail to the bottom of the cab sheetmetal. Maybe 3/8-1/2" difference depending on your body mounts...
-Chris
Old 10-13-2006, 02:08 PM   #13
XXL
Señor Member
XXL's Avatar
Gracias! I'll base my xmember mod from there and porterbuilt's measurements of the cab cuts.
Old 10-13-2006, 05:35 PM   #14
see ten
WTB this ad
see ten's Avatar
I have the ECE xmember and it touches the cab floor as designed. I don't know if that info helps you any, but I tried!
see ten is offline   Reply With Quote
Old 10-13-2006, 08:10 PM   #15
XXL
Señor Member
XXL's Avatar
Yes, that also helps... now I can confirm my measurements from the other method.
Thanks.
Old 10-13-2006, 08:53 PM   #16
Rokcrln
Rokcrln's Avatar
If you go with Porter's numbers you should be fine because his motor and trans is raised 2" due to the Dropmember! Don't forget pic's!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 10-13-2006, 11:41 PM   #17
XXL
Señor Member
XXL's Avatar
Originally Posted by Rokcrln View Post
Don't forget pic's!
Digicam died :-(
I'm trying to find an off duty courtroom sketch artist in the mean time. I'm thinking of going with this guy. He shows good use of color, and a none-too-edgy shade effect...
Old 10-14-2006, 12:52 AM   #18
PBFAB.COM
PBFAB.COM's Avatar
Digicam died :-(
Take some polaroids and scan them in!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 10-14-2006, 04:55 AM   #19
laidout69
laidout69's Avatar
XXL is your driveline a one piece or 2 piece drive line? im running a 2 piece drive line and it works fine! i had a one piece and i was blowin u joints left to right. so a guy i know told me to run a 2 piece and i have now 2 years and havent had ne problems with it! hope this was helpful!
1969 chevy
bagged, fully shaved still UnDeRcOnStRuCtIoN
laidout69 is offline   Reply With Quote
Old 10-14-2006, 11:24 AM   #20
XXL
Señor Member
XXL's Avatar
It's 1-piece. I replaced the u-joints about 5 years ago but haven't had any problems since. My reason for the xmember questions on this thread is that I'm swapping out my stock xmember to get clearance from that hump under the driveshaft that the stock one has... that's my low point on the truck. After that, the driveshaft banging the top of the (mod'd) stock xmember is next. So this should relieve both problems.
Old 10-14-2006, 03:23 PM   #21
el curioso
el curioso's Avatar
Can you run a 2 piece on a short bed?
1969 Chevy C-10 350/700r4
el curioso is offline   Reply With Quote
Old 10-14-2006, 03:30 PM   #22
see ten
WTB this ad
see ten's Avatar
I think most V8 auto swb trucks came with a 2 piece (or at least mine did). Most of the 6cyl straight shift swb trucks I have seen have had 1 piece shafts.
Old 10-14-2006, 03:47 PM   #23
el curioso
el curioso's Avatar
Okay thank you for the quick post.
Old 10-17-2006, 04:19 PM   #24
pharcyde05
pharcyde05's Avatar
well i dont know if you have it in yet but i just picked up my trans crossmember yesterday so i can get my eng and trans mounted this week i will let you know what mesurments i use on my stock hoop this is how it looks right now
pharcyde05 is offline   Reply With Quote
Old 10-18-2006, 11:00 AM   #25
Bagd72Chevy
C10 Collector
Bagd72Chevy's Avatar
I brought mine up into the floor and if it still doesn't clear, I'll throw in the 2 piece.
Bagd72Chevy is offline   Reply With Quote
