Old 10-12-2006, 01:06 AM   #1
timcos
Chief Honcho In Charge
timcos's Avatar
Passenger Kick panel fresh air vents
OK...so I am out cleaning the kick panel fresh air vents opening. I get the driver side all done (and it was completely blocked) and I went to the passenger side.
I notice there is a vacuum actuator to open and close the fresh air vent. I did not know this existed...but I think it works in conjunction with the one under the hood opening the vent there to allow fresh air to flow into the cab.
How do I check if this one in the kick panel or the one under the hood in the cowl...actually works?
Is there like a hand pump thingy?
1992 1500 4x4 Shortbed
1984 Ford F250 Supercab Longbed 6.9L Diesel
1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
1967 C10 SWB (1980-1981)
1971 C10 LWB (1998-2004)
timcos is offline   Reply With Quote
Old 10-12-2006, 02:24 AM   #2
Aarons72s
Re: Passenger Kkck panel fresh air vents
If your vacum lines are still hooked up slide the top lever on your a/c control panel all the way left with the engine running. The vacum actuator on the kick panel vent should open it, the one on the firewall should close the flapper in the cowl and the heater valve should close on the heater hoses. and if the lines arent hooked up or if your truck is disassembled just put on a small peace of vacum hose on it and suck on it to get it to retract. I then usally put my finger over the end of the hose and wait a couple of minuts to see if the thing returns to its original position, which would indicate a leak. That is how I test them to make sure they dont leak and work
Aaron
Aarons72s is offline   Reply With Quote
