Old 10-12-2006, 10:07 AM   #1
shifty
Questionable
shifty's Avatar
Need radiator mounts help!
Okay, I have a 2-row radiator in my truck (came with L6).
I just got a 4-row radiator for my truck.
My core support has the proper holes and stuff for the 4-row radiator, but it seems the upper and lower saddles don't fit it. See here (closeup):
http://satellitehead.com/uploads/radclip002.jpg
And here (at a distance):
http://satellitehead.com/uploads/radclip001.jpg
Is this just the wrong radiator for my truck, or did they make bigger saddles for my radiator support? It seems like the lower saddles are about as big as they're going to get, and I don't think I can fit any larger saddles there.
Looks like a 3-row radiator would be a perfect fit, but the guys at 1-800-radiator do not issue refunds and do not list a 3-row radiator as being for this truck.
Advice welcome.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 10-12-2006, 10:09 AM   #2
shifty
Questionable
shifty's Avatar
Re: Need radiator mounts help!
PS - how do you swap these buggers out? I just went to GMCPaul's and noticed that there are diff't ones for 2, 3 and 4 core style retainers...
Old 10-12-2006, 10:17 AM   #3
68 short step
yes they do make longer saddles.... you swap out the lowers by drilling out the rivets and put new ones in and rivet them or bolt them back on... i may have some i can send ya, ill check tonight
68 short step is offline   Reply With Quote
Old 10-12-2006, 10:20 AM   #4
PETEM1957
Junior Member
Check The Classifieds - Jose Has (2)0 Sets For Sale
PETEM1957 is offline   Reply With Quote
Old 10-12-2006, 10:41 AM   #5
shifty
Questionable
shifty's Avatar
Thanks guys. Can anyone tell me the difference in length between the 2-row, 3-row and 4-row?
The ones on my truck now (2-row) can saddle a radiator 2¾" deep.
The radiator I have now (4-row) is 3½" deep.
The radiator place is trying to replace mine with a 3-row. I can go pick it up right now - and I am curious to know if the 2, 3 and 4-row radiator mounts are the same or different.
Old 10-12-2006, 11:15 AM   #6
sleepyboy
'69 Step
I bought new mounts from chevy duty when I swapped to a 4 core.
sleepyboy is offline   Reply With Quote
Old 10-12-2006, 11:20 AM   #7
shifty
Questionable
shifty's Avatar
yeah, but they're like ... $70 for the rubber pads and all four mounts.
Old 10-12-2006, 01:42 PM   #8
Greaser
Greaser's Avatar
I Cut And Rewelded A Set Of The Top Mounts For A Guy. I Dont Know What He Did For The Bottoms Though. My Local Parts House Sells The Wider Saddle's Cheap.
Greaser is offline   Reply With Quote
Old 10-12-2006, 02:32 PM   #9
shifty
Questionable
shifty's Avatar
I just swapped it out for a 3-row Delphi radiator (Ac-Delco, possibly).
All is well. 2-row and 3-row use same mounts. 3-row is just wider. I need to figure out now how to move the bottom rad mount closest to the battery box
Thanks for all the replies. If anyone knows how to move that bottom mount, please let me know!!
