Old 10-12-2006, 06:29 PM   #1
etg
etg's Avatar
Suggestions?
I need to figure out a plan for getting new brakes on my truck. I want to do 4 wheel disc brakes eventually, but for now they are too expensive. So I am thinking of disks up front and drums in the back, does anyone know good disc brake sets i could buy online? I heard that CPP sells a kit for the front that comes with a set of drop spindles, but I dont't know how much that kit is. Any help is welcom
etg is offline   Reply With Quote
Old 10-12-2006, 06:35 PM   #2
qksilver
Re: Suggestions?
If money is an issue, and for me it always is, I would look for a 73-up donor to pull the front suspension off of. Better ride because of the rubber bushings, cheaper replacement parts and better availabilty.
Time verse money, which do you have more of.
Check out the parts for sale listings
qksilver is offline   Reply With Quote
Old 10-12-2006, 06:47 PM   #3
Aarons72s
Re: Suggestions?
qksilver,
Aaron
Aarons72s is offline   Reply With Quote
Old 10-12-2006, 07:25 PM   #4
67chevy2wd
67chevy2wd's Avatar
Re: Suggestions?
If you go this route will the whole crossmember bolt up, or just the suspension?
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 10-12-2006, 07:36 PM   #5
Boog
laying low
Boog's Avatar
Re: Suggestions?
Yes it will Andrew. I have a 69 with an 82 front under it complete.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 10-12-2006, 07:43 PM   #6
67chevy2wd
67chevy2wd's Avatar
Re: Suggestions?
Sweet, thanks.
'71 GMC 3/4 ton 4x4
Old 10-12-2006, 11:00 PM   #7
clay68c10
clay68c10's Avatar
Re: Suggestions?
I just used the later model spindles, steering linkage, and ball joints. You can keep your control arms.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
