Old 10-12-2006, 11:11 PM   #1
too much stuff
Roadtrip!
too much stuff's Avatar
Brought home a burb, fuel question?
Just bought this one, guess i needed it!!!
anyhow, its a 72 with not many options except rear air. The guy i bought it from put 6,000 miles on it since oct 86. Came from OK before that, but minnesota salt has its grip on it now. I have put about 70 miles on it and cleaned it up since these pics. My question is it looks like the gas is draining back from the carb when its shut off. Put a little gas in the carb, it fires up and runs fine. Shut it off and you have to put gas in the carb again. It has a pretty new fuel pump with the third line on it. Any ideas? It has a clear fuel filter in line that i can see the gas drains back out of. Thanks, Eric
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 10-13-2006, 05:30 AM   #2
JimKshortstep4x4
Re: Brought home a burb, fuel question?
From your description, it sounds like the float valve is sticking and not allowing gasoline into the carburetor. I would suggest checking the valve of replacing it. The carb could be really gunked up, also.
I see your Burb has rear AC!
Jim
Old 10-13-2006, 09:36 AM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
Congrats on the cool addition to your family!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-13-2006, 12:32 PM   #4
wibilly
wibilly's Avatar
eric the stock fuel filters in the carbs have check valves in them to prevent this
common sense isn't so common anymore
wibilly is offline   Reply With Quote
