10-13-2006, 08:30 AM | #1 |
Rear air bag mounting
I'm mounting my rear air bag and have the one 3/8" bolt that goes through the trailing arm. Is that enough to hold it? Seems like there should be more.
10-13-2006, 08:45 AM | #2 |
Nothing fits but the oil
Re: Rear air bag mounting
yupper, right through the arm
Land of the free Because of the brave |
10-13-2006, 09:21 AM | #3 |
I want to start with two firestone bags in the back.
Can you take some pics of your project? That would be great!
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
10-13-2006, 12:19 PM | #4 |
Is it possible just to remove the rear springs and replace them airbags with little modification and keep the front springs? Are there kits for this mod?
1972 Cheyenne 402 LWB 2005 Silverado X-Cab 5.3L 2004 John Deere L120 20HP B&S |
10-13-2006, 01:14 PM | #5 |
Thats what I'm working on too. Turns out my springs are producing different hieghts from softness or size. I'll fill mine with a air compressor for now.
10-13-2006, 01:14 PM | #6 |
A guy with a truck
Yep. You don't need a kit. Two bags, fittings, air line, and a couple of shrader valves to fill 'em. <---Less than $200 -Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
10-13-2006, 01:16 PM | #7 | |
Do you need to take the bed off to drill out the holes? Does anybody have a template as to where to drill the holes for Firestone 2600 bags? Cheers,
10-13-2006, 01:31 PM | #8 |
Outlandish Trends - FL
The 3/8" bolt is fine, just make sure you use grade 8 hardware.
67chevemall: For the template, I just took a piece of paper and traced the holes from the bag, then cut them out and mocked it up on the frame with a white marker. It was easy to drill the smaller mounting holes for the bag, the port hole (1") was the PITA.
-Bret 67 short-fleet sold! |
10-13-2006, 04:25 PM | #9 |
You're better using 2,400 lb. bags in the rear ... use the 2,600 lb. bags in the front.
10-13-2006, 04:48 PM | #10 |
2-2400 bags are on order. Bed has to come off for sure.
My torn nails will lower her and the air pump will make her stiff. Can't wait. what is the best way to drill a fn 1" hole through hard steel? ?
10-13-2006, 05:46 PM | #11 |
The bed doesn't have to come off. I did the rear on mine w/ the bed on. You're gonna spend way more time removing & replacing the bed than it will take to mount the bags and plumb the rear.
As for the best way to drill a 1" hole? I started with small bits and worked my way up, also used a unibit, and a die grinder. It takes patience more than anything.
10-14-2006, 08:26 AM | #12 |
cool.
anybody have some pics of the upper mounts? |
10-14-2006, 05:47 PM | #13 |
A guy with a truck
10-17-2006, 10:25 AM | #14 | |
http://www.suspensionconnection.com/...tion/to=r.html Not to hijack the thread, but I want to bag the rear only also on my 69 C10, with something that will have good load carrying capacity when aired up, and be able to drop the back about 3" when I'm not. |
10-17-2006, 06:03 PM | #15 |
A guy with a truck
Check out *****************. They have everything you will need at the best prices. If you have technical questions, call 'em up and they will set you up with exactly what you are looking for.
<-- Not affiliated with SD, just a very satisfied customer.
