Old 10-13-2006, 02:59 PM   #1
jimmmie '79 Cheyenne
3/4 ton ball joint replacement
Put on some new wheels and tires and the shop said my lower ball joints need replacement. I have estimates from $270 - $390 incl alignment OUCH... On the 3/4 ton they are pressed on - has anyone replaced these and what kind of a press whould you need. I can get the ball joints for about $120 and then it would be another $50 for the alignment. Don't know it it would be worth all the $U&^##@ to do it myself to save $100...
jimmmie '79 Cheyenne is offline   Reply With Quote
Old 10-13-2006, 03:45 PM   #2
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Re: 3/4 ton ball joint replacement
When I went into the alignment shop, they wanted over a G to replace my lower ball joint. I decided to do it myself and take the 'opportunity' to replace all the moving parts on the front suspension. Over the span of a few days and 'bout $200 in parts, I had the front end completed rebuilt. Your estimates of $270 - $390 sound reasonable.
If you decide to do it yourself, Auto Part Chains like Autozone loan out the ball joint press for a minimum returnable deposit. I've attached a pdf to give you an idea of replacing the ball joint on the LCA. It's fairly straightforward.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 10-13-2006, 04:11 PM   #3
Thanks...looks like something I may go ahead and do - wish I knew they were bad when I did the brakes and wheel bearings last month, oh well - another day in the garage.
Old 10-13-2006, 05:38 PM   #4
Bender
I did the upper and lowers on my truck and it wasn’t too bad. I just did it in a regular H frame hydraulic press.
The universals on the axles however were a real PITA.
Bender is offline   Reply With Quote
Old 10-15-2006, 09:13 PM   #5
mitch1965
mitch1965's Avatar
I replaced the upper and lower ball joints on my '85 K20, using the loaner press from Advance Auto Parts. Yea, the job was a pita, but it was pretty strait forward. Took about 2 hours per side. The axle shaft slides out of each side without any clips inside the pumpkin. Then a good alignment was needed. Drives great now.
'99 K1500 Tahoe, 2dr, barn doors - 350/ 4L60E, 3.73
'01 K2500HD Silverado Ext Cab - 496/ Allison, 4.10
mitch1965 is offline   Reply With Quote
