brakes
can anyone tell all of the parts i would need to do a front disk brake conversion on a 1962 gmc 2 wheel drive 3/4 ton pickup. also if there is a late model truck i can get them from. thanks
Designated A-hole!
Re: brakes
I'm not too sure on if the frames are the same, but on the 67+ trucks the front crossmembers from 71+ trucks will bolt in place, giving you updated brakes and suspension. Then you just need to replace the booster/master cylinder and plumb it up. You just need to find out if the frames are close enough for it to work for you.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Re: brakes
You can do a complete front crossmember swap easier and cheaper than buying the parts singular. Just stay with 3/4 ton, and stay 1987 & below.
1970 long fleet, 355 4 speed, primer, walnut goodies |
