Old 10-13-2006, 08:24 PM   #1
Bob Moore
Another What Do I Have Thread
Cleaning a rear axle assembly I picked up from a 72 1/2T Suburban. I thought it was a 12 bolt but maybe not. On the cast center section - facing forward - was GM60. Is this normal on 12 bolts? I remember somebody sold a 1/2T rear end as a Dana rear - for big bucks.
Can somebody look at their rear end and see if this common to 12bolts or not. The GM60 was on the drivers side of the center cast piece facing forward.
TIA - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 10-14-2006, 01:10 AM   #2
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
Re: Another What Do I Have Thread
some earlier trucks 60-66 could have a d44 rear.
what is you lug count?
trkklr77 is offline   Reply With Quote
Old 10-14-2006, 07:45 AM   #3
Bob Moore
The rear end is 5 lug.
vac, 454, T400
more to follow
Old 10-14-2006, 07:49 AM   #4
OLDROCK&ROLLER
OLDROCK&ROLLER's Avatar
how many bolts are on the cover?
72 CHEYENNE 10 SUPER
468/400/3.73
OLDROCK&ROLLER is offline   Reply With Quote
Old 10-14-2006, 08:13 AM   #5
Livrat
Member #1049
Livrat's Avatar
Bob, I have 4 or 5 1972 12 bolts laying around at the shop, I will take a look today to see if the "GM60" was common or not (I never paid any attention)
I do know that there never were any dana 44's or 60's with a 5 on 5 inch bolt pattern.. plus all of the Dana's have a screw in fill plug in the cover and 12 bolts do not..
Mark
Livrat is offline   Reply With Quote
Old 10-14-2006, 12:03 PM   #6
Bob Moore
Mark - Thanks. You have answered this ? because the oil fill is on the cast center portion and the cover does NOT have an oil fill. I have D60 3/4T that has the 60 cast on an angled rib - lower rightside and visible from the rear - and the oil fill in the cover.
Thanks everybody for your responses - Bob
vac, 454, T400
more to follow
Old 11-24-2006, 04:41 AM   #7
trkklr77
trkklr77's Avatar
back from the past.
i was looking at my diff the other day and low and behold, it has a gm61 cast in to it, its a 72 12bolt.
