Old 10-14-2006, 12:22 AM   #1
Kenneth_CS87
Lt1 Swap what do you guys recommend?
I am in search of some headers and radiator for my swap right now. What do you guys recommend for the headers and radiator? Motor is out of a 1994 Z28.
Kenneth_CS87 is offline   Reply With Quote
Old 10-14-2006, 01:02 AM   #2
Fastfun
Fastfun's Avatar
Re: Lt1 Swap what do you guys recommend?
The headers that I am using on my LT1 are from Street and Performance,
Fastfun is offline   Reply With Quote
Old 10-14-2006, 01:06 AM   #3
nandress
nandress's Avatar
Any good radiator should do. The key is probably to run electric fans rather than a fan clutch. I would assume that a stock heavy duty radiator would be just fine. On the aftermarket, BeCool has a full radiator/dual fan module specifically for these trucks...Though you might have to do some custom fabbing to get mounts to work.
nandress is offline   Reply With Quote
Old 10-14-2006, 01:31 AM   #4
Fastfun
Fastfun's Avatar
Make sure you let them know it is for an LT1 and not the stock motor. The
LT1 has reverse cooling
Old 10-14-2006, 02:30 AM   #5
Kenneth_CS87
Thanks for the help Im preatty sure that the stock C10 wont work.
Old 10-14-2006, 06:59 AM   #6
Werewolf
Woof?
Werewolf's Avatar
You've got to use electric fans on an LT-1. I'd recommend an electric water pump upgrade, too. Summit sells an LT-1 specific pump for $200. It's easy to install, just pull the pump, pull the front cover, press out the impeller shaft and impeller, and press in a brass freeze plug that comes with the pump. This will also ensure that the water pump doesn't take a pee on your Optispark when it dies. Getting an Optispark wet is one of the big reasons they fail. The other is using an aftermarket ignition box, like the MSD 6AL, with the stock system. And get a 160 degree 'stat for it, too. The reverse flow cooling system makes this "upgrade" worthwhile by keeping the heads extra cool.
If you do this, you may as well go the extra mile and replace the cap and rotor, too. MSD and Summit both sell performance caps and rotors for the LT-1, now, much sturdier than stock.
As for headers, most of the LT-1 guys I talk to swear by Hooker long tubes.
And radiator .. as Fastfun said, just make sure it's good to go for the reverse-flow cooling system. And go big if you can. I've had a couple of LT-1's and they seem to love running hot.
1968 LWB CST BB
2004 Avalanche Z71 LT3.
2003 S-10 ZR2 (hers).
1997 Astro
1992 Caprice wagon, 500k stock miles. Nursing wounds after a bad wreck.
1997 Saturn - need gas mileage from something!
Werewolf is offline   Reply With Quote
Old 10-14-2006, 07:31 AM   #7
pdr510
Junior Member
pdr510's Avatar
I am using the stock '72 chevy 4 row radiator for my LT1. I am using hooker super comp headers made for sbc with no problems. Radiator hoses is the biggest challenge using the stock radiator.
1970 C-10 Fleet Side
Gen IV 6.0 with 4L80E
pdr510 is offline   Reply With Quote
