Old 10-14-2006, 11:57 AM   #1
casterbuster
Mejor Que Nada
casterbuster's Avatar
big block swap
Ok i know several people have done this swap... And yes i have done a search already.
But, my situation is a little different from others...
In my '70 model 1/2 ton I have a 350 sbc and a 400 turbo...
I have 78 model, 3/4 ton with a 454...
my question is will the towers and springs from the 3/4 ton work on the 1/2 ton?
The only thing that separates
"Dreams" from "Reality"
is TIME and MONEY!!!
casterbuster is offline   Reply With Quote
Old 10-14-2006, 02:30 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: big block swap
The towers will be a tad tall if I remember right, The springs, they'll fit, but IMO, they'd be too tall and stiff. Try your OE springs. It'll drop maybe an inch... nothing extreem.
Old 10-14-2006, 05:17 PM   #3
corn
Re: big block swap
My 69 is big block origional. Ive had a 350 in it & now the 396 is back in it again on the same towers. I didnt have to move the trans either way. Id say bolt the motor in & drive it.
corn is offline   Reply With Quote
Old 10-14-2006, 05:29 PM   #4
Longhorn Man
Re: big block swap
You can use small block towers, but you'll be required to use headers, and you may not be able to use a factory shroud.
Old 10-14-2006, 05:49 PM   #5
corn
Re: big block swap
I had headers on both, Andy is probably right. Never even thought of that.
Old 10-14-2006, 11:15 PM   #6
RSRXION
RSRXION's Avatar
Re: big block swap
Use the 73-87 towers and mounts and the 70-72 big block shroud. I just put a 76 Chevy 454 in my 72 hauler using the 76 engine , turbo 400 transmission , mounts and trans crossmember. You'll need to position the stands like I show you in these photos and enlarge 2 or 3 of the holes but it's an easy swap. Factory manifolds and shroud are a direct bolt up. Email me at rsrxion@yahoo.com or call 479-263-3326 if you need more help. Dean
"They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." Ben Franklin
RSRXION is offline   Reply With Quote
Old 10-14-2006, 11:33 PM   #7
Longhorn Man
Re: big block swap
sweet... FAQ maybe?
Old 10-15-2006, 01:17 PM   #8
casterbuster
Mejor Que Nada
Re: big block swap
sweet,
Thanks guys for the help.
Mike
