Old 10-15-2006, 09:25 PM   #1
Rat72
Rat72's Avatar
Cigarette Ligher Install
I have what looks like a new cigarette lighter but the last owner did not complete the wiring. There is a red wire that I assume goes to the lighter socket on the fuse panel. The blue wire has a male circular plug that is unclear where it should go. My guess would be that it needs to be changed to a female blade plug and put into the lamp blade on the fuse panel. And then there is a male blade coming off of the lighter with no wire. Is this a ground and if so where is the stock grounding location?
Thanks,
Whit
Rat72 is offline   Reply With Quote
Old 10-15-2006, 09:57 PM   #2
Aarons72s
Re: Cigarette Ligher Install
There is no grounding wire just ignore the terminal for the ground. it grounds thru the dash. I am sorry but dont have any info on the blue wire.
Aaron
Aarons72s is offline   Reply With Quote
Old 10-15-2006, 10:57 PM   #3
krue
Designated A-hole!
krue's Avatar
All you need is the red wire clipped to the back iirc. Don't know about a blue wire?
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 10-15-2006, 11:08 PM   #4
jhow66
jhow66's Avatar
You have a lighter made to fit anything. Red wire to fuse panel-blue wire is for grounding when mounted in plastic dashes. (hook red wire up and see if it works-if not ground blue with a screw to dash.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 10-18-2006, 08:42 PM   #5
Kager67
what knocking sound?
Kager67's Avatar
I just got my cig lighter today. Yes, the blue wire is for the built in light. It needs to be connected to the fuse panel. As the others said, it is grounded through the steel in the dash when mounted.
Kager67 is offline   Reply With Quote
Old 12-09-2007, 03:48 PM   #6
sb69chevy
sb69chevy's Avatar
Hate to resurrect this from the dead, but where does this blue wire attach to the fuse block?
Tks. sb
1969 C/10 swb, 350, powerglide (daily driver)
2005 CRV (wife's ride)
sb69chevy is offline   Reply With Quote
Old 12-09-2007, 04:11 PM   #7
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
The light is the blue wire. Kind of cheezy, I tossed mine. I don't remember the originals having this. I could be wrong but my truck is not stock so this is not that important to me.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 12-09-2007, 06:00 PM   #8
john
member #16
john's Avatar
Look on the fuse box for a spade terminal for cluster feed. That will turn light on when light switch is turned on.
john is offline   Reply With Quote
Old 12-09-2007, 06:33 PM   #9
cdowns
cdowns's Avatar
i just splice the lamp wire into the lights on the heater control so as to limit the clutter at the fuse panel for a cleaner look// would also run a black wire from the empty lug to assure a better ground and working lighter as i've seen a number of aftermarket lighters that dont ground as good to the dash as the OEM lighters did
Old 12-09-2007, 06:52 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
no clue why some did and some didn't, but the light in the lighter idea is a stock one. One of mine had it, and I've seen it on many others. As original it is a green wire for the light.
Plug it into the cluster feed, as mentioned above, and the light in the lighter will work with the dash lights.
Old 12-10-2007, 02:12 AM   #11
72armyswbtruck
72armyswbtruck's Avatar
That is why they call you the board GURU
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 12-10-2007, 06:23 AM   #12
Longhorn Man
i learned about it right here.
