newly minted old timer
new header, anyone tried them?
http://cgi.ebay.com/ebaymotors/CHEVY...spagenameZWDVW
i am thinking about trying these guys out. the leaking most headers do has kept me away. now i have a leak in my ramshorns and i had fixed them once already. so, im ready to try the header route, but im not wanting any probs! has anyone delt with these at all?
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
Re: new header, anyone tried them?
I bought a chrome alternator from them. Good alt. - good people to deal with.
I don't know anything about the headers though. I see it says they know that they do not work well on a chevy car or truck. Many have asked what vehicles do these fit. Most people that purchase these, have knowledge of there application. We do know these headers are very popular on classic custom built roadsters with small block Chevy engines. We are quite sure these do not work well on your every day Chevy car or truck. These headers run very close to the motor mount pad. I'm sure that those running these headers have special motor mounts, or they may not even mount the engine, using the mount pad on the block. We have heard that some trim the motor mounts to accomadate these. We just don't know much about their use. One thing is for sure we have sold several hundred sets , and seldom here of problems. |
ahhh i missed the NOT part lol. thanks for pointing that out. darn, now im back at square one.
they dont fit the 67-72 trucks.....motor mount stands are in the way ....
http://cgi.ebay.com/ebaymotors/CHEVY...em260039675596
i guess these would be the ones to get. one questionthough. how do they work with truck that have a/c? i seem to remember that the compressor mounting bracket uses the first 2 bolts one the rams horns.
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban Last edited by mtdave2; 10-16-2006 at 05:26 PM. |
99.999% of exhaust header leaks are due to poor installation techniques and/or crappy gaskets
Saving 1 truck at a time!
Those don't fit '73-'87 Chevy trucks either without very significant motor mount modifications. Street rod only, I suspect.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
Post Whore
So just curious will stainless steal headers resist discoloration or will they still look pretty crappy after a few thousand miles?
Drew '71 Chevy 350/TH350 Hugger Orange Currently just a rolling frame, body work soon to follow!!! Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927 Daily Driver: 1997 Chevrolet S-10 with more gears than pistons ![]() |
dont know what the part number of the headers that i got from them off ebay but they are great. Ceramic Shorty's for $150. Nice fit and great to deal with the seller.
1972 Chevy Cheyenne 20 1979 Chevy Camaro 2007 Chevy Avalanche 2005 Mini Cooper |
the trick to installing headers so that they don't leak is to bolt the headers up to the motor and bolt the reducers up to the flange and then weld the exhaust to the flange....and use BLUE locktite on the header bolts...i can't remember what the number of the locktite bottle is, but it resists hydrolicing from the oil in the bolt holes if there is any.... and when you hang your exhaust make sure that itdoesn't pull on the reducer before you weld it....i put headers on my truck almost 2 years ago and haven't had a problem with them since....i would also sugest that you try a normal header instead of a block hugger as when you hit bumps and such it will pull down on the reducer and have a better chance for a leak
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you." '84 chevy half ton short box 2wd, 67,000 actual miles ![]() '03 chevy 1500 HD crew cab 4x4 standard box, 6.0L ![]() ![]() ![]() |
#11 | |||
Union Electrician
I got these from them http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
I can't attest to fitment yet, but they said will fit, so we'll see.They are pretty nice for the money, I also got a 100amp chrome i wire from them too and it is very nice and the best price I could find @ $76. Shipping was REALLY SLOW ON THE HEADERS, like about a month, so I suggest you verify that they are in stock beofre purchasing.
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
Just get Headmans and forget the stainless. Stainless will work harden with time and crack. Looks good and won't corrode but will crack. There was a Jeep body available(still is maybe ) that was stamped out of stainless and it was a real problem with cracks. The bumps twists and vibration flexes the material and the result is work hardened stainless that will crack. I am skeptical!
#13 |
I like them very nice might have to try some. I dont think the stainless will wear that much unless you drive it a ton and have them on for many many years. But dont know for sure.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
#14 |
anyone know about the a/c compressor mount? will it work with headers?
#15 |
NOT REALLY BANNED!
![]() Join Date: Jul 2004
I had to build custom motor mounts in my 65 shortbed to get them to fit. Wasnt worth the troubles.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily. 04 Pontiac GTO 04 Ford Mustang GT 68 C20 LWB stripper truck 73 K5 Cheyenne 76 C20 Sierra Crew SRW 88 K20 Suburban I'm not hammering on metal just to hammer, i'm creating a piece of art. |
#16 |
I got the same ones as Byrd but haven't finished the engine yet. Also to the reverse rotation high volume water pump. Shipping was ok don't remember how long but wasn't bad.
2008 Ford FX2 Screw 1971 C10 project in shop now! 2004 Pontiac Grandam (wifes) 2000 Cavalier z24 (gas saver) |
#17 |
as far as AC mounts you use the stock frant mounts then you either fab a rear one(very easy) ior purchase a rear one from someone like hooker headman etc
headman headers fit real good yes but uf you lower your truck they hang way low under the frame /i had a 4/3 drop and speedbumps and driveways they were scrapin on a very regular basis
#18 |
I found it interesting in the ad for the cermic coated headers like byrd has they say they would never recomend stainless steel headers in there shop. But yet they sell stainless and recomend them over ceramic in the ad for the stainless?
