![]() Join Date: Sep 2005
carb help
carb on my truck is leaking gas out of the linkage??? was looking at a carb from advance auto parts 142.88 but their carb has coke linkage on it the carb on my truck just has a heat riser can i mody my truck and install a coke cable or should i look for one with the heat riser on it? http://www.partsamerica.com/ProductD...ype=26&ptset=A
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Re: carb help
i'd just put a choke cable in...automatic chokes are a pain in the arse to set...never have to set a manual choke
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you." '84 chevy half ton short box 2wd, 67,000 actual miles ![]() '03 chevy 1500 HD crew cab 4x4 standard box, 6.0L ![]() ![]() ![]() |
Re: carb help
ttt
Re: carb help
ttt
Chinook Arch
Re: carb help
I bought a new Holley Street Avenger, and I've been really satisfied with it. Electric choke works every time, and the truck starts beautifully. Easy to tune, and good performance. Had to ditch the stock air cleaner, and plug some holes in the intake that the heat riser used. And had to change around the fuel line, and buy a bracket for the throttle cable, as well as an adapter to go from the square bore Holley to the spread bore Quadrajet manifold. A little tuning on the mixture screws with a vacuum gauge, and it's great.
1972 GMC 1500 Custom - Bought used by Grandpa in '74, currently back on the road after a long hiatus. Elsie's truck 2.5" dual exhaust with Hooker Aero Chambers Holley 670 Street Avenger Edelbrock Performer RPM on GMPP 290HP 350 ECE drop 3.5/5 |
Re: carb help
I agree, for street performance the Street Avenger is hard to beat.
