Old 10-16-2006, 07:07 PM   #1
79blazer
79blazer's Avatar
My inline fuel filter is a clogging champion.
I'm sure there's a few of you who have added inline fuel fulters in your trucks as insurance for a newly rebuilt carb. I did on mine and it has clogged up twice now. I just pick one off the shelf. I used a 3 in by 1.5 inch one the first time and one twice that the 2nd time. This time I am going to try a clear plastic one. Hope to see what I catch! First time took a month to clog and the second a week. It will do it when you let the tank level drop. I need to empty it and clean it, but I was just wondering what people successfully use. -David
79 Blazer Cheyenne, 2wd 305 3.42 stock
85 Caprice, TBI converted, new 350 crate motor, Monte Carlo SS Wheels, Bilstein shocks,
79blazer is offline   Reply With Quote
Old 10-16-2006, 11:04 PM   #2
aggiedave98
Re: My inline fuel filter is a clogging champion.
I've got an '89 burb w/ TBI and it has a "factory" inline fuel filter on the frame rail. I've never had a problem with it clogging. I replace it every couple of years.
The clear should help figure out what the problem is. If you have your old one why don't you cut it open??
I'm not sure how the pickups work, but I'm having trouble figuring out why it matters that the fuel level drops... seems like the pickup is fixed and is always sucking gas from the bottom of the tank...
aggiedave98 is offline   Reply With Quote
Old 10-17-2006, 03:22 PM   #3
79blazer
79blazer's Avatar
good point. will open it up.
Old 10-24-2006, 10:31 PM   #4
lurch115
lurch115's Avatar
or a better idea instead of taking the chance of a spark and it igniting....try running some gas or brake clean backwards through it onto a paper towel or a clean rag....
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 10-24-2006, 10:33 PM   #5
aggiedave98
ok, so good point on the risks... I tend to probably take gas too lightly...
but how would you run gas or break clean backwards through it???
Old 10-24-2006, 10:58 PM   #6
71SWBChevy
Post Whore
71SWBChevy's Avatar
Yeah unless you have some great way to cut that thing open without risking a spark don't cut it open, it may blow up in your face, then you wouldn't be able to see what you catch in the plastic one either, or drive your truck for that matter!
Drew
'71 Chevy 350/TH350 Hugger Orange
Currently just a rolling frame, body work soon to follow!!!
Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927
Daily Driver: 1997 Chevrolet S-10 with more gears than pistons
71SWBChevy is offline   Reply With Quote
Old 10-25-2006, 11:59 PM   #7
aggiedave98
all right, are we starting nominations for idiot of the month yet???
Old 10-26-2006, 11:03 AM   #8
79blazer
79blazer's Avatar
Though if I'm careful I could use a hacksaw, but a roling pipe cutter would cut it open slowly and safely. I am just going to not use the second filter, and let the original one clog up, and it is an exposed one in the carburator. Its not clogging fast, though... its been over a week!
Old 10-27-2006, 01:24 AM   #9
84 400
Sb 400 club
84 400's Avatar
hmm that would sound like the tank has debreys in it or the lins. did you fill it up while a gas station was being refilled lately? when they refule they stir up sediment in the stations tanks
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 10-28-2006, 09:11 AM   #10
cableguy0
when the fuel level drops the fuel sloshes around a lot more stirring up all the crap in the bottom. when the tank has more in it its more stable. you need to just drop the tank and clean it out or get used to changing filters often. it doesnt take a whole of stuff to clog a filter
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-28-2006, 09:15 PM   #11
centsless
sufficiently talented fool
centsless's Avatar
If your state has started using E-10 unleaded recently, it will break all of the debris in the system loose and plug the filter. If that is the case, it will get better in time, just keep changing the filter.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
