Old 10-17-2006, 02:08 PM   #1
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
HELP, my truck's choking
I think it's an exhaust issue, but am not certain. My truck recently has been running rough. It idles fine, but seems like it's falling on its face at top end. It sounds as if it has an exhaust blockage or something. I checked the other day, got up underneath it and put my hand up behind both tailpipes to chk pressure. The pass. side was definitely blowing a lot harder than the driver side. A few weeks ago I noticed one of my pipes at the manifold was loose, and a nut was missing, so I put a new nut on and tightened everything down. Now I'm noticing this. What gives? There's some kind of spring actuated lever on the stock manifold, I checked that and it moves freely. Could it have broke and maybe be in the partially closed position? My low end is great, top end sucks.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 10-17-2006, 04:51 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: HELP, my truck's choking
This the little bugger. If you can't move the lever then it's froze and causing you too much back pressure giving the symptoms you describe. You should be able to pull the block off and free it up or just knock the butterfly out and put it back as a spacer. Being in Fla. you don't really need it for cold engine warm-up. If you can free it up and use it, all the better.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 10-17-2006, 05:27 PM   #3
67Fleet
67Fleet's Avatar
Well, I don't think it's that butterfly mechanism. I can move it freely and I just double-checked it in case, and I can hear it moving inside the manifold. Any other ideas? I gave the entire exhaust system a visual inspection and I can't find any dents or crimps in it from hitting anything. I'm stumped.
-Bret
Old 10-17-2006, 05:34 PM   #4
zden
check the plug wires for a burn or make sure they are all firing. mine did about the same it ran great until you put a load on it and then it ran like crap. its worth a look maybe.
1966 Chevrolet Suburban
1955 Chevrolet Bel Air
zden is offline   Reply With Quote
Old 10-17-2006, 07:00 PM   #5
Werewolf
Woof?
Werewolf's Avatar
That "spring actuated lever" is a heat riser. I think it's supposed to sort-of block some of the exhaust gases from leaving the manifold so that it causes the manifold to warm up faster, which in turn forces the hot air pickup tube to get hot air into the intake sooner. It's an emissions device, essentially, and if you have an open air filter, there's no point in having it. I'm not positive on this, but it's what my dad told me years ago. You know how those old memories stick with you.
What size exhaust are you running? 2" duals should be enough for a mild 350. You'd need bigger for a more powerful engine. Is your carb giving you enough CFM's? Do you think maybe you're running lean at the top end? Where's your redline?
1968 LWB CST BB
2004 Avalanche Z71 LT3.
2003 S-10 ZR2 (hers).
1997 Astro
1992 Caprice wagon, 500k stock miles. Nursing wounds after a bad wreck.
1997 Saturn - need gas mileage from something!
Werewolf is offline   Reply With Quote
