Old 10-17-2006, 07:38 PM   #1
z10kl
z10kl's Avatar
Brake advice
I have been reading the posts on drum to disc conversions and am not sure which way to go. I just bought a 70 cst. Why not just put 72 stuff on it? I don't mind going to 5 lug. I guess I would change the rear axles also. If I did would it just be the spindals, calipers, rotors, MC and propor valve. I assume the control arms are the same. Any advice appreciated
z10kl is offline   Reply With Quote
Old 10-17-2006, 08:07 PM   #2
qksilver
Re: Brake advice
72 fits well but replacement parts are more expensive. The reason to use 73-up stuff is because of the price of parts plus if you use the control arms you will have rubber arm bushing slightly better ride.
qksilver is offline   Reply With Quote
Old 10-17-2006, 08:18 PM   #3
z10kl
z10kl's Avatar
Re: Brake advice
Does the 70 not have rubber bushings in the control arms? And what are the pros and cons of 5 lug or 6 lug?
Old 10-18-2006, 03:01 AM   #4
Brad
Out of the carpool lane.
Brad's Avatar
Re: Brake advice
I recommend the 73+ due to the rubber bushings and cheaper parts that are easier to work with. It used to be that 5 lug was recommended due to the wider variety of wheel styles out there, but not so much anymore-alot more variety in 6 lug nowdays.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
