Old 10-17-2006, 10:10 PM   #1
mdlackey
Bolt-In Seat Replacement
Does anyone know if any other stock Chevy bench seats will bolt-in to the factory holes of a '68 C-10?
Thought I read on here, before the web site layout change-up, that some of the more recent Chevy model beanch seats would ...
Thanks,
Dave
mdlackey is offline   Reply With Quote
Old 10-17-2006, 10:51 PM   #2
roj2323
Re: Bolt-In Seat Replacement
with a welder and enough time anything will fit =)
roj2323 is offline   Reply With Quote
Old 10-18-2006, 08:53 PM   #3
qksilver
Then would they be bolt in?
qksilver is offline   Reply With Quote
Old 10-18-2006, 10:20 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
As far as i know, there are no direct 100% bolt ins from other vehicles. However, the floor is pretty flat, and many seats go in with minimal fab work.
Old 10-18-2006, 10:23 PM   #5
shifty
Questionable
shifty's Avatar
Someone mentioned that a Ford Tempo bucket seat fits our truck really well - let me find the thread.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 10-18-2006, 10:32 PM   #6
shifty
Questionable
shifty's Avatar
Search never lets anyone down, right?
http://67-72chevytrucks.com/vboard/s...ghlight=taurus
It was Taurus seats. Pics are in that thread.
Old 10-19-2006, 08:32 PM   #7
Green Machine
Green Machine's Avatar
We're going to use a bench seat from an 88 Chevy truck, will need to drill some holes, but supposed to be a good fit.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 10-19-2006, 09:14 PM   #8
If you can find an 88-94, then seem to work the best (for a bench) in my opinion. The 95-98 got a bit thicker in the cushions and you would loose more room. Here is a set from a 90 C1500 that I had in my 70. I got stupid and decided to go buckets. I now wish I had kept the bench, but.
The space I used was a 3/4" to 1" pipe fitting which was perfet height.
Old 10-19-2006, 10:38 PM   #9
RSRXION
RSRXION's Avatar
As others have said... 88 up. But be careful of thickness because the cushy padding will sit you higher and further forward. I'm 6'3" and 250 lbs. The 01 style Silverado seats place my head against the top of the cab and my knees up around my ears. It's not very comfortable.
I'm using a split bench out of a 91 or so in my hauler. I had to drill new mounting holes and reinforce them from the bottom of the cab but that's no big deal. The seat is a hell of a lot more comfy than a stock 67-72 seat as well. I'm also using the belts out of a late model Tahoe/Suburban . They're a bolt in and use the factory anchor above your shoulder. Here's a pic of the seat .........
"They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." Ben Franklin
RSRXION is offline   Reply With Quote
Old 10-19-2006, 11:05 PM   #10
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
They would be when I got done with them!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
