Old 10-17-2006, 10:34 PM   #1
magnethead
7000 #'s of american IRON
magnethead's Avatar
NTS: truck is not tank, weighs a tank
Ok, so my friend with a 67 mustang is stuck on the side of my (loose gravel) road from sliding off into the ditch accidently
I go to turn around to hook up to him, and i proceed to get stuck perpendicular to the road taking up most of the width of it. Even with throttle management, because of the position my truck was sitting in (nose in the ditch, rear axle on the loose stuff), it was no time at all before i was bottomed out on the running boards and I had 4" deep ruts under all 4 rear tires.
so my friend that was with me with a ram 1500 hooks on to my trailer hitch to try and pull me sideways. He gets not even a few inches after the rope gets tight before he's stuck spinning his tires in the loose stuff...ain't either of us got detroit's or anything.
So the origional person's mom arrives in a 2500 silverado and tries to pull my back end around, and i'm pulsating the throttle in reverse while she's pulling me, and there's gravel going everywhere (including in the cab) and there's nothing but gravel in my rear rim except gravel up to above the hub cap (you couldn't see any of the hubcap). I look down on one of the pulses, and the tach flies to 4,000 RPM. About then, her truck starts digging down into a rut.
So we still have a mustang stuck in the ditch, and my truck stuck nearly perpendicular to the road with 18" of gravel packed up against the left rear tire.
about 45 minutes later, both of us are finally extracted, with the road left a royal mess.
just because my truck weighs a tank and has the structural strength of a tank, does not mean it pulls like a tank in all conditions. So now i'm leaking some fluid or another (either PS or trans, more likely P/S).
Oh, and i managed to catch a piece of 2x4 almost to the point of fire from having it under my right rear tires trying to lift them up...I pulled it out and blew on it and it turned to an orange glow....
magnethead is offline   Reply With Quote
Old 10-18-2006, 12:34 AM   #2
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: NTS: truck is not tank, weighs a tank
Yipes, sounds like a complete disaster to me. I know what u mean about that loose gravel and those certain angles. Glad everybody was able to get unstuck.
-Later
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 10-18-2006, 02:05 AM   #3
84 400
Sb 400 club
84 400's Avatar
glad tpo hear you got out. if not it might have been a back hoe or tractor that would have to have done the deeed. it is times like that that we all wish we had a 4 wheel drive truck but ahh i still love my 2wd
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
