Old 10-17-2006, 10:37 PM   #1
wolfthing2000
Nice orderly plug wires
Probably been discussed a lot . I was wondering what is available to run a nice neat wire layout that is somewhat out of sight, like from the back of the engine and around under the headers. Summit sells something that is a bracket affair and routes the wires through what looks to be a billet plate with bushings or grommets arranged 4, 3, 2, 1 and looks like it bolts to the block maybe??? I am running the Hedman Elite hedders and the engine is a small block with MSD distributor.
Any pics or links are greatly appreciated .
Thanks once again for all of your knowledge guys.
wolfthing2000 is offline   Reply With Quote
Old 10-17-2006, 10:46 PM   #2
qksilver
Re: Nice orderly plug wires
corvettes run the wires under the manifolds. I have seen dist caps that are reordered so that the plug wires for one side of the engine go to one side of the cap
qksilver is offline   Reply With Quote
Old 10-17-2006, 11:07 PM   #3
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Check out the Crossfire HEI cap, it's $44.95 but its awesome for the ordering of wires, 4 straight out per side.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 10-17-2006, 11:35 PM   #4
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
I'm using these looms with these plug wires. I realize that the looms use the valve cover hold down bolts to hold them above the headers & next to the valve cover, as opposed to under the headers like you asked, but its essentially the same thing. I routed the wires back behind the heads & up to the cap. You gotta use a custom fit wire set like the ones below to do this though. It's very clean & simple. As for under the headers - i think summit has what you need - you just have to use custom-fit wires.
http://store.summitracing.com/partde...5&autoview=sku
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 10-17-2006, 11:36 PM   #5
passthebuck
wolfthing - that was your 1000th post. Congrats!
passthebuck
#5642
Old 10-18-2006, 12:16 AM   #6
QKENUF4U
QKENUF4U's Avatar
Thumbs up Re: Nice orderly plug wires
THANKS !!! exactly what i need !!!
QKENUF4U is offline   Reply With Quote
Old 10-18-2006, 01:55 AM   #7
jimmydean
jimmydean's Avatar
I got these off ebay for $30
I saw them on a motor someone posted and had to have 'em. I have a new set of valve covers on the way too, should clean up the engine real nice like.
jimmydean is offline   Reply With Quote
Old 10-18-2006, 05:18 AM   #8
Ackattack
Ackattack's Avatar
I ran my plug wires under the headers. I had to use the custom length wire set that you cut to length.
I did this before I put the engine in, and was able to remove the headers easily. I just used a few zip ties to keep them tight and away from the headers. It looks nice and clean, but it makes them a pain to work on (not that I really have done anything with them, but if I do) Just something to consider.
I don't have a picture of it right now....I'll try to find one later though.
Ackattack is offline   Reply With Quote
Old 10-18-2006, 09:11 AM   #9
wolfthing2000
WOOOOOOOOOOOOO HOOOOOOOOOOOOOO!!!!!!! 1000 posts!!!! Glad ya pointed it out.
Good info too
Old 10-18-2006, 10:05 AM   #10
rcatalano
rcatalano's Avatar
Although not the greatest picture, I used looms from a company named Made For You on my 69 Camaro. The picture kinda shows the vertical version that mounts to the valve cover.
I used standard MSD 35599 wires that route under the headers.
I can take some better pictures if it would be helpful.
Rick
rcatalano is offline   Reply With Quote
Old 10-18-2006, 12:07 PM   #11
wolfthing2000
Does the MSD custom set come with the crimping tool????
Old 10-18-2006, 12:14 PM   #12
passthebuck
yes it does.
passthebuck
#5642
Old 10-18-2006, 02:07 PM   #13
wolfthing2000
passthebuck, thanks for the info. I am doing what you did. So If I got it right, the set up and loom look similar to jimmydeans set up????
Old 10-18-2006, 05:04 PM   #14
passthebuck
No problem wolfthing - jimmydean's look sexier than mine BUT yup, very similar. Remember to get looms for whatever diameter wires you are using - OR if the loom blocks are plastic like mine, I just drilled them out... good luck!
passthebuck
#5642
Old 10-18-2006, 07:22 PM   #15
lurch115
lurch115's Avatar
if you buy a wire set for a Corvette the wires are long enough to run under the headers as that is what i did on my truck..i can't remember the part number right off hand, but i do know it was an MSD wire set for a 70 something vette
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 10-18-2006, 08:26 PM   #16
Jim_PA
I did the same thing when my engine was out, and used a bunch of wire ties to keep them neat and orderly. When they are disconnected, they can only reach the plug that they need to go on, so it's pretty easy to work with. It's really handy when you need to remove the valve covers, and cleans up the engine bay a lot.
Jim_PA is offline   Reply With Quote
Old 10-18-2006, 10:35 PM   #17
wolfthing2000
Jim_Pa, are those bare aluminum valve covers I see there??? I have some gold anodized Moroso brand that I was thinking about stripping. Is that what yours are???
Old 10-18-2006, 11:51 PM   #18
Jim_PA
They are polished aluminum; they came that way. I'm not even sure what brand they are, but they are pretty beefy, a real nice set actually.
Old 10-19-2006, 03:40 AM   #19
Ackattack
Ackattack's Avatar
Here are mine
Old 10-19-2006, 09:28 AM   #20
Orange
Licensed to Thrill!
Orange's Avatar
That's what I have - they do a nice job.
I am using them with some Accel 8.8 race wires - so I had to open them up a little where they dump out so I could get them to clear my headers all nice and good.
They are Billet Specialties. They come with stuff on them too (milled). I like the plain though...
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 10-19-2006, 11:52 AM   #21
jimmydean
jimmydean's Avatar
Minie arn't plain either, not sure why they are in the picture (taken from the auction). I didn't even notice until you said something
Old 10-19-2006, 07:42 PM   #22
jamon8
jamon8's Avatar
under the header is the best way to go
jamon8 is offline   Reply With Quote
