08-14-2002, 03:06 PM | #1 |
Flamin' Bass
Radio, what radio?
Last week I posted this pic of some pieces.
08-14-2002, 03:10 PM | #2 |
Flamin' Bass
This crappy pic shows what happened to the pieces. Boy, it's tough to photograph shiny objects so there's no glare. It looks better in real life.
Rick Olson /nosto/ Galloway, NJ Pics : http://community.webshots.com/user/nosto53 1972 Triumph TR6 - full resto, now with a Toyota 5-speed 1975 F**D F-100 - rusty, but reliable 1982 HD XLH-1000 1967 C-10, shortstep, 350/M21 4spd, nitrogen tank fills fast bags on 4 corners, Toyo 255/45X20s on American Eagle 221 20X8s, shaved locks and handles, antenna, fuel filler, tiny C-notch, rear fuel tank, long headers, Edelbrock, worn 600 Holley, Checkmate flush hard cover, rear pan, custom LED taillights - painted it, too! But don't like it so I'm gonna do it again!! |
08-14-2002, 03:10 PM | #3 |
SLICER AND DICIER
I see what your doin, Looks like a good Idea, post pics of the full bag setup when done.
Sorry I was posting whiole you were posting the after pic. LOOKS GOOD. How come only 3 switches, front , rear, and all up/down, maybe?
01 Tahoe 22's 2/4 drop and tv's 68 chevy money pit 51 chevy belair 95 Honda 900RR 05 GMC Siearra (company truck) Last edited by NSANE68!!!; 08-14-2002 at 03:13 PM. |
08-14-2002, 03:15 PM | #4 |
Flamin' Bass
Sheesh! That last pic looks real bad. No, there's no dark line under the switches, that's glare or shadow or something.
Here's a passenger side view. When I put the gauges in flat, I couldn't see the left side of the gauge, so I put them in on an angle.
08-14-2002, 03:28 PM | #5 |
Flamin' Bass
NSANE68 - Almost. This is a 4 corner system (you know, 8 valves, 4 port 6gal tank) so I have front, rear and pancake on the dash.
I'll have the individual corner switches, for when I need to level things out, tucked away somewhere else. I didn't want to go the Nintendo controller route, but, hmmmm....maybe if what I've got works.... BTW: I _was_ going to do the 2 way system (Both front, Both rear) until I found out from the board that you'll get bleed through between L and R sides especially when you corner. It's great to always get good advice from those members who've BTDT .
08-14-2002, 03:31 PM | #6 |
Flamin' Bass
NSANE68 - Duh, I re-read your post. Your WERE right - Front, Rear, and (I'm still learning the terms) all 4 up-down, aka, pancake.
08-14-2002, 03:32 PM | #7 |
SLICER AND DICIER
Yea, I seen in your sig it was a independent system at 4 corners, but the 3 switches through me. I figured it was front, rear, and pancake. I just couldn't figure why you wouldn't want idividual control of corners for level. But that makes sense now.
01 Tahoe 22's 2/4 drop and tv's 68 chevy money pit 51 chevy belair 95 Honda 900RR 05 GMC Siearra (company truck) |
08-14-2002, 03:34 PM | #8 |
yes i did post something
man that looks nice!! was it tough doin those angles? how do you do all that stuff??
you can want in one hand and s h i t in the other and see which fills first NO MATTER HOW BEAUTIFUL THE GIRL(S) IN MY AVATAR IS PLEASE READ MY POST |
08-14-2002, 03:41 PM | #9 |
Flamin' Bass
Thanks!!
The angles were pure luck. If you look at them up close, you can see they aren't exactly the same. The gauges just happened to fit nicely inside a 2"ID piece of tailpipe connector. Just cut it in half, grind off the galvenizing (outdoors, with a mask!!) cut holes in flat panel, mark where you think the angle should be, and weld. Holding them while welding _was_ a little tricky!
08-14-2002, 03:41 PM | #10 |
very very cool
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
08-14-2002, 03:42 PM | #11 |
got any in progress pics to show us? I would like to see the welds on that plate. LOOKS SWEET!!!!!
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
08-14-2002, 03:44 PM | #12 |
Man that looks great and thats a creative idea too!
