Junior Member
Tilt Questions
Hey all,
I just received a rebuilt original truck tilt column that I ordered off ebay, My question is do I need to do any special prep work to my truck to mount this column or do i need any other parts to make the swap? I know there is prep work involved for a van column, but I dont know what if anything I need to do to mount an original tilt. Thanks
72 Cheyenne Super ShortBox, Factory Big Block, A/C PS PB. 71 Cheyenne LWB, 350, A/C, 48k Miles 70 Olds Cutlass Convert, A/C, 350 auto, 66k actual miles. 82 Corvette, Triple Black, 32k Miles, Had since new. 85 Caprice Coupe, Bottle fed 383 Stroker, 30k miles. 06 Dodge Charger Daytona, Top Banana Hemi. |
![]() Join Date: Aug 2001
Re: Tilt Questions
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
its all about the +6 inches
Re: Tilt Questions
If the turn signal switch was replaced durring the refurbishing, you may need an adapter for the plug. Look at the plug, if it is half moon shaped, then you are good to go... plug and play, if it is flat, then go to your dealer and order P/N189451, it should be about 10 bucks or so IIRC.
Junior Member
Re: Tilt Questions
Thx for the info,
I already have the wiring adapter with the column, so I should be good to go, might dive into it in the morning, I will let you guys know how it goes.
Where's my beer?
Re: Tilt Questions
Post some pics of the install
Paul How do you make the invisible, visible?.........You take it away. |
