Old 04-23-2002, 04:15 PM   #1
BigDave
I poop on Ford!
BigDave's Avatar
Post Blazer Owners: Where to Buy Roll Bars - Headache Racks
Since I posed the question about rigging a 3-point seatbelt or harness system in my Blazer it appears the best way of doing this is by utilizing a roll bar or headache rack.
Since the Blazer is 2WD and street driven only, I'm only looking for something to protect me in the rare event of a rollover. I don't want something made from extra large gauge metal or large diamter.
I'd obviously need something that would be compact enough to fit under the top. I would want it to be either black, chrome, or white. I would also be interested if it came pre-rigged for a 3-point seatbelt. It would also be nice if it were a kit I could install myself.
Links?
1972 Chevy Blazer 2WD - 400 SBC, bored, ported/polished heads, 9.5:1 dished pistons, Lunati 480/292 cam, electronic ignition, Edlebrock Performer intake, tricked out Rochester 850CFM Quadrajet, long tube headers, Flowmaster 40's, TH350-C with lock-up switch, 2800 rpm stall, shift kit, custom driveshaft, stock GM 12- bolt rear with Auburn Pro Series limited slip 3.73's, 2" drop spindles, 2" drop rear coils, track bar kit, front/rear stabilizers.
1999 30th Anniversary Trans-Am Coupe #1494 - M6, Flow-tech cut-out, Flowmaster, free mods. One of 292 coupes with M6 and in-dash CD.
1972 Chevy Cheyenne - LWB, factory 402BB
2005 Chevy Suburban LT
2006 Chrysler 300C - SRT8
BigDave is offline   Reply With Quote
Old 04-23-2002, 05:51 PM   #2
Mike C
Mike C's Avatar
Post
Your best bet is to adapt something to the holes in the top. A 4 point harness would require a cross bar behind the seats to mount the shoulder straps to. That would significantly limit the access to the back seat, especially if your truck is lifted. Smittybuilt makes a bolt in 4 point bar and a weld-in conversion for a cage.
70 GMC 3/4 ton Sierra Grande 402/TH400
72 Jimmy 4WD 4spd 4" & 35's
64 Corvette Coupe
68 Camaro 'vert TPI & TH700
69 Z/28 355 12.6's @110
72 Datsun 240Z-ol' reliable
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
02 GMC 2500HD 4x4 Duramax
Old 04-23-2002, 06:38 PM   #3
Alexis
Member since 2000
Alexis's Avatar
Post
i got the same one, you can get them at 4wheel parts or call smitty directly
Mechanic @ California Concept
Britney: 1970 2wd K/5 Blazer (Frame up)
Jessica: 1967 2wd SWB (pops daily driver)
Helga: 1972 4x4 3/4ton LWB (my daily driver)
AIM:Alexmart1
Mountain View, Cali
Alexis is offline   Reply With Quote
