Old 10-18-2006, 06:49 PM   #1
Batmat
cab mounts
I need a little help here. I just got my cab mount kit from Kenny's Trucks. (1971 2 wheel drive short bed). I have a bag with the following: 6 bolts all the same length, two are slightly thicker, 8 washers (two for the thicker bolts, the remainder for the smaller bolts), 6 metal spacers three sets of different sizes, 6 round poly mounts, 4 tapered poly mounts, and two tapered (different) mounts, and six nuts. Its been so long since I took the cab off, I cant remember how the mounts go on. Any help would be great, (pictures or drawings would be a benefit. Thanks
Batmat is offline   Reply With Quote
Old 10-18-2006, 06:55 PM   #2
Aarons72s
Re: cab mounts
Do you happen to have a lmc truck catalog. Flip to the page that shows the body mounts and it will show you how everything goes. By the way the thick bolts go in the front holes in the cab. Oh and if you dont have there catalog just go to there web site. They have there catalogs scanned on there server.
www.lmctruck.com
We always say that lmc parts arent usually that great but there catalogs make good manuals.
Aaron
Aarons72s is offline   Reply With Quote
Old 10-18-2006, 09:08 PM   #3
Batmat
Re: cab mounts
I looked at their catalog. they mail me one every month or so, so I keep them all over the shop as reference material. in the catalog, it is hard to tell which mount goes where and which metal sleeve I use at each location.
Old 10-18-2006, 09:26 PM   #4
70c10
67-72 Addict!
70c10's Avatar
Re: cab mounts
This may help: http://67-72chevytrucks.com/vboard/s...ghlight=mounts
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 10-19-2006, 06:22 PM   #5
Batmat
Re: cab mounts
Thanks 70c10, that is just what I was looking for.
