Front Crossmember reply..thanks
Thanks for everybody's help with the cross member. The 76 is finally in. I have mocked up the control arms with the 3 inch drop spindles and just picked up some trick brackets for the air bags in the front. The plan is to first weld in the bottom mounts and drill the holes for the air lines. Then I will take it all apart again and replace the bushing and ball joints...thanks again for the advice on the new crossmember...it ended up being about 3/4 of a inch wider but I was able to make up the difference with some washers and overall I was very happy with the results....Does anybody know how to post pics....I have some pretty good shots
Reason: adding pic
