Old 10-19-2006, 02:00 PM   #1
71sub
71sub's Avatar
Cool fuel pump -- stock or aftermarket HiPo
I'm gaving problems getting fuel to my Edelbrock 600cfm and need to replace -- here's the dilemma ... When should I upgrade to an aftermaket 7-8 psi mechanical vs the stock 3-4 psi mechanical pump OR even electric ?!!!
Yes, my engine is slightly modified : intake, headers, cam, exhaust, HEI ...
Let me know what you think.
71 C/10 : 350 / 700r4 ; Ford 9" posi 3.50 with 31x10.5 rear tires, single drive shaft, C-notch, 2.5" drop spindles, keyless entry
71 Suburban 350/350 -- caddy tail lights, keyless entry, late model seats, billet Autometer instrument cluster
70 Ford Torino -- 351W (balanced & blueprinted ), C4, VDO gauges
71sub is offline   Reply With Quote
Old 10-19-2006, 02:18 PM   #2
Ole Blue 68
Ole Blue 68's Avatar
Re: fuel pump -- stock or aftermarket HiPo
My 350 has been modded and the stock fuel pump does fine getting fuel to my Edelbrock 1406 carb.
Ole Blue 68 is offline   Reply With Quote
Old 10-19-2006, 02:44 PM   #3
jimmydean
jimmydean's Avatar
When my fuel pump works, the stock one is fine. I replaced it a few months ago and it's acting up again.
jimmydean is offline   Reply With Quote
Old 10-19-2006, 02:52 PM   #4
bryanw1968
bryanw1968's Avatar
You "should" be fine with the stocker pump. I had a pretty decent 383 with a stock pump on it and it ran fine. On my current small block I went with a low pressure(5-6psi) Carter pump and love it.
When you say it's acting up what do you mean? Do you have any bends in the line? Also, if you have a 90 degree fitting coming out of the pump to the carb you're loosing up to 30 percent flow. Try a radial mandrel bent one if you don't already have one.
bryanw1968 is offline   Reply With Quote
Old 10-19-2006, 03:03 PM   #5
Yukon Jack
Post Whore
Yukon Jack's Avatar
I'd give Eldebrock a call - seems most carbs are happy with the stock pressure. I believe the quadrajets actually have problems when you get to higher pressure than stock.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-19-2006, 03:06 PM   #6
bryanw1968
bryanw1968's Avatar
Yukon Jack,
Haven't ever mentioned it, but your ride is freakin' awesome!!!!!!
Love the bed. A buddy of mine has a '72K5 and it's making want a 67-72 4X4 bad!!!!
Old 10-19-2006, 03:12 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You don't want to raise the pressure on an edelbrock either, some stock fuel pumps have too much pressure.
Get a stock replacement, you'll be fine.
Old 10-19-2006, 04:37 PM   #8
71sub
71sub's Avatar
OK -- cool ... thanks for ALL the input !
What do you mean by a mandral radial bent line ..... a line that has more of a rounded , flowing bent vs a sharp 90 off the pump ?
THANKS !
