Old 10-19-2006, 06:34 PM   #1
braggwood
Cab?
70 and 72 cab, are they the same cabs? Thanks, Greg
braggwood is offline   Reply With Quote
Old 10-19-2006, 06:43 PM   #2
Werewolf
Woof?
Werewolf's Avatar
Re: Cab?
There were minor differences, but nothing that should inhibit a changeover. Purists might know when looking, but I doubt anybody else would.
1968 LWB CST BB
2004 Avalanche Z71 LT3.
2003 S-10 ZR2 (hers).
1997 Astro
1992 Caprice wagon, 500k stock miles. Nursing wounds after a bad wreck.
1997 Saturn - need gas mileage from something!
Werewolf is offline   Reply With Quote
Old 10-19-2006, 06:52 PM   #3
braggwood
Re: Cab?
I am thinking about a chopped top, the 70 cab has a good top and rotten bottom, my 72 has a good bottom but rusty above the w/s.
Old 10-19-2006, 07:00 PM   #4
wibilly
wibilly's Avatar
Re: Cab?
what year did they switch from 3 door bumpers to just two?
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 10-19-2006, 07:05 PM   #5
sameyrasmea72
sameyrasmea72's Avatar
Re: Cab?
The r/v mirror on the 72 was mounted to the windshield, and on the 71 and earlier it was mounted on the cab. A 71 cab will have a raised area for the mirror , the others will not
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 10-19-2006, 10:17 PM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Cab?
Cab vent in the door jamb area also tells the tell..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 10-19-2006, 10:25 PM   #7
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Re: Cab?
....and the firewalls are different: 67-70 & 71-2 due to the mounting shapes for the accellerator pedals.
The fuse panels were also different, so I think the firewall holes for them are also different.
PICKMUP is offline   Reply With Quote
Old 10-19-2006, 11:26 PM   #8
Solver
Solver's Avatar
Re: Cab?
pretty sure fuse box was the same for 69-72
68 and earlier were turned horizontally.
so 70 vs 72 you are looking at mirror hole in cab on 70 none on 72 (mounts windshield
vent on door jamb on 72 none on 70
different holes for foot feet bracket mount
2 studs sticking up from floor(for foot feet bottom) on 70 none on 72
and a square hole on the 72 for the accel cable round on 70
different size id plates and gvw plates
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
