Old 10-19-2006, 07:00 PM   #1
pimperout
pimperout's Avatar
longbox stepsides
i was just thinking about mabe buying an old long stepside from a friend of mine but im not sure about which vehicle its off of so i was just wondering if long stepside boxs will work on a 70 GMC 1500 from a 55-66 year truck, if any of these boxs will work what are the differences in them, they dont look all that different from what i have seen, thanks
pimperout is offline   Reply With Quote
Old 10-19-2006, 07:08 PM   #2
sameyrasmea72
sameyrasmea72's Avatar
Re: longbox stepsides
other than the fenders, they are very close.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 10-19-2006, 09:19 PM   #3
pimperout
pimperout's Avatar
ok thanks
Old 10-20-2006, 12:37 AM   #4
sameyrasmea72
Before you make a decision let someone on the board explain the difference a little closer. I know the bed will work, but there are a few difference that someone can explain to you.
The same step beds were used untill '87.
72 Cheyenne Super
Old 10-20-2006, 01:57 AM   #5
pimperout
pimperout's Avatar
alrite thanks fer the tips
Old 10-20-2006, 01:40 PM   #6
MAR-Ktech
Truck Parts Mfg.
MAR-Ktech's Avatar
There are many subtle differences that keep this from being a simple bolt-on conversion, even though the beds all look about the same. The 55-66 year series included four distinctly different beds and the problems are different depending on which one you want to use. http://www.mar-k.com/bed_side_interchange_gm.html will give you some idea of the differences and help you decide if you want to do the swap. The differences include rear sill, rear sill mounting positions, cross sills, angle strips holes, front panel bed strip holes, bed wood and bed-to-frame bolts locations. These in addition to the obvious fender and its bolt pattern. The parts needed to make the change easier are available from most vendors. Good luck on your project.
Mar-Ktech
The link above specifically applies to short beds but many of the problems you may have are the same for long beds.
GET MAR-K Quality!
Restoration and Custom Pickup Parts for Chevy, GMC, Ford, Dodge and Custom Trucks
Last edited by MAR-Ktech; 10-20-2006 at 01:44 PM. Reason: Clarify the link application to this truck
MAR-Ktech is offline   Reply With Quote
Old 10-21-2006, 04:28 PM   #7
pimperout
pimperout's Avatar
YES!! thank you very much thats exactly what i was looking for thank you
