Old 10-19-2006, 09:25 PM   #1
6(sic)6
6(sic)6's Avatar
Drivers headlight problems. (3rd time!) please help.
at first i had Stock bulbs, then my drivers side burn'd out so i got a pair of h4 upgrades.
installed them then about 5 months after using them. drivers side BURN'd out again.
so i bought some good $38.00 bulbs on ebay.
NOW tonight it burn'd out again.
ive changed the dimmer switch. (even though i know thats not the problem)
but what should i look at and try to fix????????
so that i can QUIT buying bulbs,
this summer im out for college, and i dont need to be dealing with problems with my truck.
ANY advise greatly appreciated.
Daily Driver:
383 sbc
Shaved.
lowerd
6(sic)6 is offline   Reply With Quote
Old 10-19-2006, 09:29 PM   #2
cdowns
cdowns's Avatar
Re: Drivers headlight problems. (3rd time!) please help.
ground wires// make sure you have good grounds from headlights to core support/ then make sure you have good ground wires from the coresupport to the frame rails
Old 10-19-2006, 10:32 PM   #3
centsless
sufficiently talented fool
centsless's Avatar
I agree. With a bad ground, the current could be rapidly starting and stopping just like constantly turning the lights on and off. It would not be that noticeable, and would affect bulb life.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 10-20-2006, 01:36 AM   #4
kbs71
71 rustless in texas
kbs71's Avatar
Also check your bulb connectors. Make sure there clean and tight. A loose connector can drive the resistance up causing the bulbs lifr to deminish rapidly.
"The secret to creativity is knowing how to hide your sources."
"No one really listens to anyone else, and if you try it for a while you'll see why"
71 C-10 LWB presently in a perpetual state of disassembly
'96 Toyota (my work car)
'04 Mustang Convertable (wife's car & other money pit)
Latest aquesition and why my trucks still in the garage covered with junk..
2010 Aqua Blue metallic 6 speed Manual LS3 2SS/RS Camaro (I want one of these in my truck
FAQ here
VENDORS here
SUPPORT THE BOARD here
My second favorite SITE
kbs71 is offline   Reply With Quote
