Old 10-19-2006, 09:28 PM   #1
SIR
SIR
SIR's Avatar
sway bar...pro's & cons?
.....I'm thinking of adding a sway bar to the front of my "66" pickup and I need some "input" on how well they work...thank you....
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 10-20-2006, 01:33 AM   #2
ghetto_superman
ghetto_superman's Avatar
Re: sway bar...pro's & cons?
sway bars are SWEET. im sure someone else will help you out with compatability from other trucks so you dont have to buy a new one (a ripoff IMO) if you can find an inch and a quarter sized one from a junkyard that will fit from a newer truck, get the mounts, some new urethane bushings and your truck will feel as much like a racecar as it can considering its a huge un-aerodynamic steel brick!
no downsides btw.
ghetto_superman is offline   Reply With Quote
Old 10-20-2006, 12:56 PM   #3
salazar44
65 - Chevy C10
salazar44's Avatar
OMG... is that underneath a 1 week old chevy truck or underneath a 40 year old chevy?????
VIC
One Repair Leads to Another!
http://vix65chevyc10.blogspot.com
salazar44 is offline   Reply With Quote
Old 10-20-2006, 03:04 PM   #4
64 C-10
64 C-10's Avatar
My '64 has a front sway bar and handles great,
Go ahead and install one, you will notice a big difference.
64 C-10 is offline   Reply With Quote
Old 10-20-2006, 03:10 PM   #5
SIR
SIR
SIR's Avatar
....yup...It's 40 years old!!! it's just re$tored..thanks!!
Old 10-20-2006, 06:18 PM   #6
Fastrucken
Junior Member
Fastrucken's Avatar
I just upgraded from a 15/16 in front that the PO put on there to an 1 1/4 bar from a one ton 6 pack with poly bushings, 73-87 is the years of trucks you'll need to look at. The difference is huge its a must have. The front end doesn't rock up when you take a corner. I also have a camaro rear bar that wil be put on shortly. Again its a must have.
A good friend will come bail you out of jail, but a true friend will be sitting next to you saying, "That was ****ing awesome."
Fastrucken is offline   Reply With Quote
Old 10-20-2006, 10:56 PM   #7
Frizzle Fry
Frizzle Fry's Avatar
Yep, fully agree. It's like going from driving a canoe to an indy car (not a harsh ride though, just feels like a newer vehicle). Get the 1.25" bar from a 73+ 3/4 ton+ 2wd. Energy suspension bushings and ECE mounts for lowered trucks (or no mounts like my Burb). All the 67-72 stuff will work. Camaro rear bar adds even more stability, but going from no bar to a 1.25"er will be a HUGE improvement by itself.
Frizzle Fry is offline   Reply With Quote
Old 10-22-2006, 02:03 PM   #8
poncho_villa
poncho_villa's Avatar
I have to agree that there are no cons and all pros. Although my truck is a 58 it sits on a 64 chassis. When I got it, it didn't have sway bars. Only lots of body roll going around corners, so I had to slow right down. I installed aftermarket bars front and rear (trailing bars with coils) and now it corners like a slot car. Next to power steering, this is the best upgrade I have done. No regrets. Installation was a breeze and they look great.
poncho_villa is offline   Reply With Quote
Old 10-22-2006, 05:48 PM   #9
Woogeroo
some info I compiled a while back... it may or may not help.
http://woogeroo.home.mindspring.com/.../swaybars.html
-W
Woogeroo is offline   Reply With Quote
Old 10-22-2006, 09:56 PM   #10
SIR
SIR
SIR's Avatar
.thanks gang!!! I'll be placeing my order with "ece" on monday...keep up the good work!!!
