10-19-2006, 09:36 PM | #1 |
chevy truck fan
late model power steering pump removal
hi guys,
i have '72 chevy p/u with a 92 suburban serp. belt setup on it. i have a flex-a-lite twin fan setup as well. my question is basically this: how do i remove the pump?? i am hoping that there is someone else on this forum that has switched to a late model serp. setup that has had to do this already & can give me some very appreciated insight!! i am really at MY WITTS END!!. i don't think that there is enough room to remove the pulley 1st. maybe someone can give "step by step" instructions for the order to do things anyways. i am able to get to all the bolts except for the one behind the pulley on the pass. side. if anyone here could (would) help me i would be very greatful!!! thanks for the time to help! rodstored-72 |
10-19-2006, 10:02 PM | #2 |
Re: late model power steering pump removal
I think the only way to access the bolts is to remove the pulley
10-19-2006, 10:23 PM | #3 |
chevy truck fan
does anybody know if a puller from a local parts house work on the space?? i have about 3.5" of free room???
thanks for the help. |
10-19-2006, 10:33 PM | #4 |
That should be enough if you use the collar style puller. It will be close though
10-19-2006, 11:11 PM | #5 |
MY 90 Burb is the same way, have to remove the pulley first, I have to jack the fan shroud a little bit to get the puller lined up straight
10-20-2006, 10:55 AM | #6 |
chevy truck fan
does anyone know if the "collar style" puller is available to rent from the local parts store?? i assume that maybe the counter person would know what that style of puller is.
thanks!! rodstored-72 |
