1 ton single wheel frame.....
Is a 68 1 ton frame single wheel the same as what came under a dual rear wheel frame?
Thanks, Steve |
Re: 1 ton single wheel frame.....
I would think so, probably the only other difference might be a heavier set of leaf springs? The 67-72 factory assembly manual would show that,or somebody on here with more knowledge than me. I'm sure somebody will answer your question pretty quick.
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart 1998 Chevy 1/2 ton ex cab V-6 5 speed 1967 Chevy SWB - project truck; not started just yet |
Fabricate till you "puke"
Yea, 1 ton singles is a longhorn, or 9' step(133" wb). Thats the same frame under a short 1 ton dually, but as mentioned, the spring package is different
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
turbo enthusiast
my '69 one ton dually has a 175" wheelbase, but the frame does look like it had 4 feet or so added to the end of it. Could take a pic if needed.
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting ![]() |
![]() Join Date: Aug 2003
Only if it's 133 wb.
I think the factory also put out a 157" wb cab/chassis....but you might shout at Andy(longhorn mail) to be sure on the specs.
But, wouldn't the frame still be different (taller) at the back on the 157" wb?
its all about the +6 inches
the frame is taller on all one tons, but that doesn't matter, the frame is the same, single rear or daul rear... I think the springs may even be the same... just way more likely to have overloads on a daulie.
Thanks guys............I didn't want to ask to many questions until I looked at it. For the price it's a good deal but the frame would be a bonus.
get up! stand up!
frame and springs are the same. andy's correct--duals more likely to have auxilliary spring setup.
9FT STEPSIDE CLUB 40 1-1/2 ton stake 67 c30 disassembled & for sale 70 gmc 3500 canadian 9 foot "fenderside" pickup 06 silverado 71 vet enjoyed by my retired father ![]() wtb-67 chevy 1 ton 9ft stepside-in perfect condition |
