Old 10-19-2006, 11:10 PM   #1
rancid
rancid's Avatar
gmc rear springs
i just bought a 72 gmc sierra 1/2 ton 2wd and it has leaf springs in the rear, i thought all 1/2 ton 72,s had coils.
rancid is offline   Reply With Quote
Old 10-19-2006, 11:13 PM   #2
kwmech
Re: gmc rear springs
Not always, I have had a couple of 1/2 tons that have had leafs. Guess it was the way it was ordered from the factory or load options
Old 10-20-2006, 12:56 AM   #3
sameyrasmea72
sameyrasmea72's Avatar
1/2 ton chevys had standard coils with optional leaf, while all 1/2 ton GMC's came standard with leaf. This is true for 72, not sure about other years
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 10-20-2006, 09:14 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
gmc had leafs generally... in 69 they had coils standard... not sure if there were any other years like that or not.
Old 10-20-2006, 10:20 PM   #5
stacerbob
BODY SHOP SUPPLIES INC.
stacerbob's Avatar
I had a '69 GMC back in high school, it had leafs. It was also a custom cab, had upper, lower & trim around the bottom of the cab roof. It had ps pb ac tilt tach 3.73 posi turbo 400 and a 250 inline 6!!! think somebody checked off the wrong engine on the order sheet!!!
stacerbob is offline   Reply With Quote
Old 10-20-2006, 11:06 PM   #6
ETsC10
Hand Crafted C-10
ETsC10's Avatar
I have both a '68 GMC and a '68 Chev; both 1/2 ton. The GMC had the normal leaf springs, the C-10 was factory equiped with a leaf-spring Posi. Nice option but an option none-the-less. I thought all GMC's had leaf springs and don't know if they even offered a coil spring rearend.
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
Old 10-21-2006, 06:30 AM   #7
72freak
Rottenwood Garage Member
72freak's Avatar
This original 69 GMC had factory leafs in the rear......and boy......they were stout!!!! The last time I had a home renovation project I filled the bed with old wall plaster and lathe. It then rained over night. When I got to the dump I knew I was heavy (low tires) so I went through the scales. The rear had little to no sag at all and the weight of the truck was 9200 pounds. Thats over 5000 pounds of material and almost no sag!!!!
Try that with a coil spring and see what happens.
72freak is offline   Reply With Quote
Old 10-21-2006, 09:13 AM   #8
eagle23
Active Member
Do you still have that truck??
eagle23 is offline   Reply With Quote
Old 10-21-2006, 05:41 PM   #9
72freak
72freak's Avatar
I wish......it was sweet oroginal ride!!!!
A punk on 75N at Cartersville was racing around in the rain and lost controll and hit me. When it was all done I hit the back of a guardrail going backwards doing 60+mph. There was nothing but mangled metal left. Suspention wast trashed, entire body was trashed and I think about all that was good was the engine.
It was a VERY sad day!!!
Old 10-22-2006, 02:51 AM   #10
llegos
i have a 1969 GMC and it has leaf spring in the rear, and i can also vouch for the stiffness on these things...
-Steve
llegos is offline   Reply With Quote
