10-20-2006, 12:25 AM | #1 |
7 blade fan for small block
I am looking for a 7 blade fan for my 350. What kind of car can I get one off of? Waterpump is a short one with a fan clutch.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
10-20-2006, 08:38 AM | #2 |
Re: 7 blade fan for small block
You can get a new one from O'Reilly's....just ask them at the counter. If you are set on the yard search, you can check old station wagons and trucks with HD cooling packages [usually included with tow package].
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
10-20-2006, 08:46 AM | #3 |
I took the one I had laying around from my 1971 Monte Carlo and bolted it on. It looks a heck of a lot like the ones on my Chevelles too.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
10-20-2006, 11:17 AM | #4 |
Have you tried ebay? I've had great success with flex~fans on there.
10-20-2006, 11:32 AM | #5 |
"Trucks with Class"
The 7-blade clutch fan on our trucks was on AC only. Do you need the fan, clutch or both?
Be careful using fans off other vehicles. A lot of them were bigger and if you run them and the engine moves a little under power they will tear up the fan shroud...or more. |
10-21-2006, 01:08 AM | #6 |
I have the clutch I just need the fan it self. What size is that fan? Have looked on ebay and seen one or two but have not had much luck getting a response when I ask the diameter of the fan.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 Last edited by skokie; 10-21-2006 at 01:11 AM. |
10-21-2006, 08:51 AM | #7 |
TRY ONE OFF OF A CHEVY VAN UP UNTIL THE MID EIGHTIES. GET THE SHROUD TOO AS THE LOOK JUST LIKE THE ONES ON OUR TRUCKS, BUT HAVE A LITTLE LARGER HOLE & ARE ABOUT TWICE AS HEAVY DUTY. THERE THICKER & GREAT FOR A DRIVER. I USE EM ON ALMOST ALL OF MY TRUCKS. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
10-21-2006, 10:23 AM | #8 |
I got mine off a 77 Monte Carlo.
77 swb starting all over again. |
10-21-2006, 10:05 PM | #9 |
What is the diameter of the 7 blade fans? 18 or 19?
